January 22, 200818 yr Xentient Thumbnails v1.0.2Info: Free utility for replacing the generic icons of image files with thumbnail icons of the actual image.MD5: B3EB03277F75EFC6C04AB1CA10D9CE48Size: 327 KBWebsite: http://xentient.com/products/thumbnails/
January 29, 200818 yr not working ,why ???????????it might be helpful if you were a little more specific
January 30, 200818 yr I have checked this and found that after integration (run in vmare) in c:\WINDOWS\system32\ShellExt there was xthumbs.dll. After extracting and installing the addon manually then the thumbs.dll was there as well and could see the nice thumbnails...Rick you any idea?
January 30, 200818 yr Try this:Copy xthumbs.dll as "thumbs.dll" to dir "C:\WINDOWS\system32\ShellExt"Then run a cmd and navigate to "C:\WINDOWS\system32\ShellExt"type "regsvr32 thumbs.dllAnd its done Thanks for the addon rick, thats a great addition to windows xp.
January 30, 200818 yr Author Yea sorry my fault, I forgot to add the CopyFiles to the OCEntry[DefaultInstall]CopyFiles =DLL.CopyRegisterDLLs=Thumbs.Register[Xentient Thumbnails]OptionDesc ="Xentient Thumbnails"Tip ="Free utility for replacing the generic icons of image files with thumbnail icons of the actual image."Modes =0,1,2,3CopyFiles =DLL.Copy ; I forgot this line RegisterDLLs=Thumbs.RegisterFixed... plz redownload
January 30, 200818 yr Thanks Rick :thumbsup_anim:still dasn t work :crying_anim02:,still dasn t work :crying_anim02:,i use nlite and after install not work this addon,pliss help, and i dont now why . Edited February 23, 200817 yr by ricktendo64
February 23, 200817 yr Author OK I found the problem, it was my entries.ini file. It did not rename the file on copy buy i fixed it nowxthumbs.dll = 1,,,,,,,30,0,0,thumbs.dll <- I forgot thisRedownload grzegorzo, same link, same addon filename just verify with the md5 hash
February 23, 200817 yr Thank you,very much ,i am testing :thumbsup_anim::thumbsup_anim: :thumbsup_anim: :thumbsup_anim: WORKING , THANK YOU
February 24, 200817 yr Umm, this slowed down my xp too much. And, lastly i've disabled the cache. Cool addon though.Thanks again Rick.Edit: Check "Start\Control Panel\Xentient Thumbnails" for app settings. Edited February 24, 200817 yr by MrNxDmX
February 24, 200817 yr i've never had any problems with slowdown using it.. i've tried to find alternative programs but havent found any that does what this one does.
May 4, 200817 yr i noticed is that its not showing up in add/remove properties, nor is there a folder for it listed under start>programs... i'm curious if this was intended?edit: well it seems to be working properly, but as far as i know it cant be uninstalled. i suppose its not that big a deal Edited May 4, 200817 yr by ccl0
May 4, 200817 yr Great. Nice find. I still need to upload some fotos and this tool will make selecting the right pic's easy:D
May 31, 200817 yr This keeps failing for me. Textmode setup keeps asking for the files. I'm guessing it's because RVMi is compressing the files so the names are changing. Would that effect it? Thoughts?
