[Addon]Foxit PDF Reader 3.1 Build 0901
Foxit Reader 3.1 Build 0901
An exclusive small and fast PDF Reader!
Foxit Reader is a free PDF document viewer and printer, with incredible small size (only 2.55 M download size), breezing-fast launch speed and rich feature set. Foxit Reader supports Windows Me/2000/XP/2003/Vista. Its core function is compatible with PDF Standard 1.7.
you can download the addon
from here
MD5:8DA9C7D441EC96477B5C7DAF6BFAD87F
website: http://www.foxitsoftware.com/
hope you like it
ChangeLog
17-9
Updated To 3.1 Build 0901
15-7
Updated To Build 1817
2-2-09
Updated To Foxit Pdf 3 Build 1301
4-9
Updated to Build 3201
30-6
Fixed wrong type in Entries<<< sorry my fault coz of speed
29-6
Fixed the ShortCut Problems
Edited by DaRk MaDnEsS
not working, 0 shortcuts
it should be working but it seem that it doesnt work partly
so i`m working on this problem trying to find a better way to make this short cut
thier is a problem in it coz of the space in the name
hope i fix it fast
and you better try to reinstall it
i will do my best and tell you.
Edited by Dark_Knight
Fixed the short Cut problem
It should now make it right
using the same way
test it then tell me
remember that foxit has asked (repeatedly) that people not redistro their software in any form.
oh :o
i just found a good product so i tried to make it an addon
to help people out it a great tool for pdf and i use it all the time
and if you want to delete it its ok no problem
I don't know if they have changed their mind or what.
Taken directly from the end-user lic agreement......
7. REDISTRIBUTION: User can redistribute Foxit Reader under this agreement under the condition that User agrees not to redistribute Foxit Reader on mobile devices or embedded devices including cellular phones, PDA
for real i`m not good in english :D
so does this mean i can make it an addon or not
plz answer
if any problem i`m here to help
  • 4 months later...
Updated To Foxit Pdf Read 3.0
i will add the Addons For Foxit Soon
Usually I integrate Foxit addon as super must have.
I am MSFN forum member. And there is one utility that configures installation of programs in addons for WPI and extracts executable files to temp folder.
I have created 220 free program set but there is one addon, yours, that I cannot convert.
After decompressing all files I have: foxit.inf, FoxitReader.exe, FoxitReader_Preferences, Readme.txt, Uninstall.exe (Entries_...ini not needed I think).
Is it correct if
- I put all them exept readme.txt to install folder
- and in section [sourceDiskFiles] of foxit.inf remove readme.txt
- No switch for executable file will be applied, that's exe file will chew silently foxit.inf?
Is it correct if
well there is to ways
first convert this one into Exe one and that needs to modify my inf to remove the prompt
In Install Section Change it into This
[install]
;BeginPrompt =BeginInsPrompt
Runpresetupcommands =Create.i386:1
AddReg =FOXIT.AddReg
CopyFiles =FOXIT.FILES
ProfileItems =Desketop.AddShortcut,Foxit.AddShortcut,Uninstall.AddShortcut
RunPostSetupCommands =Delete.i386
;EndPrompt =EndInsPrompt
and remove the Readme From [FOXIT.FILES]
And ReCompress The Files Into Cab Or change
1="WinXp","Foxit.Cab",,I386
with
1="WinXp","WIN51",,
And It Should Work Fine
second you can use my silent installer << it`s an svcpack addon using the original installer
From Here
i already made it from a while but didn't make a Topic for it
after downloading go to svcpack folder and copy the Exe file
  • 4 months later...
Updated !
sorry for late Update
i already made the addon since a couple of days and forgot to post
so Updated to 3.1 Build 0901
  • 16 years later...
