August 26, 200818 yr Before After OverviewThis software installs Windows Easy Transfer on a Windows XP-based PC. This software is already built into Windows Vista, so it is not necessary to install it on a Windows Vista-based PC. Windows Easy Transfer enables you to automatically copy your files, photos, music, e-mail, settings, and more to your new Windows Vista-based PC. This makes it much easier to setup your new computer with all your personal data and settings. This software provides support for transfering data with Easy Transfer Cables or across a network, external drive, or CD/DVD. As an alternative to downloading, Windows Easy Transfer can be installed from the CD that came with your Easy Transfer Cable, or by following the directions in the Windows Vista version of Windows Easy Transfer on how to copy the program to Windows XP.System Requirements * Supported Operating Systems: Windows XPWindows Easy Transfer supports the following operating systems:1) Windows XP SP2 to Windows Vista2) Windows Vista to Windows VistaWindows Easy Transfer supports transfers via any one of the following methods:1) USB Easy Transfer Cable2) Network connection3) Removable media (such as a USB flash drive or external hard disk)4) CD or DVDWindows Easy Transfer (transfer files and settings from XP 2 Vista)Info: This addon fully replaces the XP Files and Settings Transfer Wizard with the Windows Easy Transfer from Vista SP1.Program is replaced/installed in \WINDOWS\system32\usmt and you will find the shortcut located in All Programs->Accessories->System Tools.Downside: The Windows Easy transfer only works from XP -> Vista or Vista <-> Vista, does not work XP <-> XP or Vista -> XP so if you want functionality instead of style then stick with the original migwizWarning: Integrate with nLite only (v1.4.9 and up.) Also this ONLY works with same language Operating System as the addon was made/translated for. en-US (English)MD5: b9b195440554e1b937b61f088ebcff3cSize: 6.17 MB es-ES (Spanish)MD5: 773446E71530D4B0065BD26A2FCB9E98Size: 6.22 MB tr-TR (Turkish)MD5: 486A658B428F178F39E4B7F477ED5D38Size: 6.22 MB nl-NL (Dutch)MD5: C32FDF4527189D95E12BEC1648F818C7Size: 6.22 MB de-DE (German)MD5: 12914394D071DB12886FF20B0BF8A5C1Size: 6.22 MBWebsite: http://www.microsoft.com/downloads/details...EC-4928FA173266<div class="offtopic_all"><div class="offtopic_top" onclick="show_offtopic(this);"><span class="offtopic_title">Off-Topic Comment</span><span class="offtopic_desc">(Click to Show)</span></div><div class="offtopic"> Translations Requests WelcomeIf you want this program translated into your language here is what I need:1- I need these .MUI files from any of the specified locations on a Vista (SP1) DVD or install (in the language you want it translated to)----------MUI Files:----------input.dll.muimigautoplay.exe.muimigres.dll.muimigsetup.exe.muimiguires.dll.muimigwiz.exe.muispwizres.dll.mui----------MUI Dirs:----------X:\support\migwiz\xx-XX (DVD)%SystemRoot%\System32\xx-XX%SystemRoot%\System32\migwiz\xx-XX2- Tell me what language nLite says your OS is?3- TXTSETUP.SIF and SYSSETUP.INF/IN_ from the language you want it ported to4- I may need help translating these Strings:migwizShortCutName = "Windows Easy Transfer"migwizActionName = "Transfer files and settings"migwizAddonTip = "Migrates files and settings from one computer to another."<span class="offtopic_close" onclick="this.parentNode.style.display='none';">[Close]</span></div></div>
September 1, 200818 yr Author Updated to FINAL now that nLite 1.4.9 is out and the script.dll obsolete_files bug is gone. nLite will warn you if you try to remove Files and Settings Wizard (this is a feature requested by me to stop ppl from removing stuff a addon might depend on)Added Dutch version...still open to more translation requests
September 1, 200818 yr Deutsch (Deutschland)migwizShortCutName = "Windows Easy Transfer"migwizActionName = "Dateien und Einstellungen WET.7z Edited September 3, 200818 yr by Helmi
September 3, 200818 yr Helmi I need allot more than that, read my list of thingsOi, missed #3!Anyway, that's just two files, right?Not really "a lot more", innit? EDIT: Ok, other post edit, missing files added to archive.Hopefully I got it all this time.If not, I dunno what could be missing still Edited September 3, 200818 yr by Helmi
September 3, 200818 yr Author Sorry helmi I assumed because of the very small size of the atachment you had not provided the files I needed (bad guess)Added de-DE version for you, let me know if goes well, it shouldBTW wrapped/hid the translations requests with offtopic BBCode
September 7, 200818 yr Yeah, well, the two files from XP were indeed missing, I simply overread your request for them Anyway, thanks for your work, gonna try this on my next disc and report how it goes.
September 14, 200818 yr Worked perfect with my latest update pack with ie7. But as i understand from its purpose, this addon replaces windows xp's file and setting transfer wizard with windows easy transfer. A goodie for my windows xp disc Cheers buddy
October 22, 200818 yr I found a custom GUI for USMT by samohtrelhe.http://usmtgui.ehler.dk/This could be a cool replacement for XP -> XP or Vista -> XP or 2000 -> Vista, etc
December 29, 200817 yr I integrated the english version with nLite, but it isn't in english :confused02:
December 29, 200817 yr Author DAM! there was a turkish mui in there, its fixed nowBTW if you want to fix this without the need to re-install you can download the new addon & extract miguires.mui then rename it to miguires.dll.mui and copy it to \WINDOWS\system32\usmt\en-US
December 31, 200817 yr DAM! there was a turkish mui in there, its fixed nowBTW if you want to fix this without the need to re-install you can download the new addon & extract miguires.mui then rename it to miguires.dll.mui and copy it to \WINDOWS\system32\usmt\en-USThanks, but I tested in a VM, so I'll just dump it in the i386 folder or whereever nLite sent this little addon of yours
November 13, 201015 yr New version is outhttp://www.microsoft.com/downloads/en/details.aspx?FamilyID=734917d8-0663-4c26-89d0-2d00b632ebdb
October 16, 201115 yr I tried to integrate this into my install and I kept getting some error about the catalogs being invalid. Removal of the add-on eliminated that error message during GUI setup..... Any advice?
