Posted May 12, 200916 yr Remote Desktop Connection v6.1.7600.16385(x86)About: The following addon completely replaces the program Remote Desktop Connection of XP SP3 (same version from Vista SP1) with the original one from Windows 7. This version resolves some errors with the current Remote Desktop Client when used with certain visual styles...Thanks to ricktendo64 for his help in creating this addon. He also created a spanish version available here.Note: There will be an errors in setuperr.log because the files are not digitally signed but this is common and does not do damage.True Addon - Works only during unattended install - It replaces files in the i386 folderDownloadMD5: 5aee63d76578eb9de1a79dc014d9e559SIZE: 1.22 MBSilent Installer - Works anytime - It replaces files in the System32 folder.This installer uses WfpDeprotect to disable SFC for 1 minute, to allow overwriting the original protected files. This WILL enable SFC when WfpDeprotect completes. It is not recommended to use this if you have disabled SFC with nLite or some other means. You will need to extract from 7-zip files before using.DownloadMD5: 24d02a33b930d3a2b66101f3c897af94SIZE: 1.13 MBThis installer does NOT use WfpDeprotect to disable SFC. Use this if you have disabled SFC with nLite or some other means. You will need to extract from 7-zip file before using.DownloadMD5: 6a88e6460855b3317b74ead071881dd8SIZE: 1.15 MB Edited December 7, 201014 yr by Jonnyboy
May 12, 200916 yr Are you sure this works?I've downloaded end expanded the files within but... First, it demands an lhmstsc.exe.mui instead of lhmstsc.muiSecond, after renaming the file manually, it claims mstscax.dlll i have does not match the version of the client shell. (6.0.6000 didn't work as well as 5.1.2600)I couldn't run it in the end.(:
May 12, 200916 yr Author Are you sure this works?I am positive it worksI've downloaded end expanded the files within but... First, it demands an lhmstsc.exe.mui instead of lhmstsc.muiSecond, after renaming the file manually, it claims mstscax.dlll i have does not match the version of the client shell. (6.0.6000 didn't work as well as 5.1.2600)Look at layout.inf and see the filenames are renamed during install.Also, verify the file version after you copied the files. The correct version of each file is 6.1.7100.0. Have you disabled SFC?This is an addon for building an unattended install, this will not work in a live system. I will create a silent installer that will work in a live system. Edited May 12, 200916 yr by Jonnyboy
May 12, 200916 yr Author I've written a silent installer that will work in a live system or during an unattended install. It uses WfpDeprotect to disable SFC for 1 minute and then copies the files to the system. I need to run a few more tests to verify that it works, then I'll post it. Edited May 12, 200916 yr by Jonnyboy
May 12, 200916 yr Author added silent installer that will work in a live system or during fresh install
May 14, 200916 yr works nice .. thanksbtw- WfpDeprotect is nice little toy too; hadn't seen that one before :thumbsup_anim:
May 17, 200916 yr Author works nice .. thanksbtw- WfpDeprotect is nice little toy too; hadn't seen that one before :thumbsup_anim:Yep, it was a nice find and it worked out great.
May 18, 200916 yr just a footnote ... I ran the silent installer from svcpack slipstream and installed perfectly ... although I have sfc patched (disabled) by nlite ... didnt think wfpdeprotect would effect anything ... but think it did ...was replacing a file later and sfc blocked me ... I thought oh sh**t lol ....no problem I deleted dllcache...and replaced sfc dlls from my iso and got rid of sfc.so just in case, I think wfpdeprotect is enabling sfc after that 1 minute, perfect for sfc enabled install, but for anyone with sfc disabled to begin with, might find it enabled after that minute.
May 19, 200916 yr Author just a footnote ... I ran the silent installer from svcpack slipstream and installed perfectly ... although I have sfc patched (disabled) by nlite ... didnt think wfpdeprotect would effect anything ... but think it did ...was replacing a file later and sfc blocked me ... I thought oh sh**t lol ....no problem I deleted dllcache...and replaced sfc dlls from my iso and got rid of sfc.so just in case, I think wfpdeprotect is enabling sfc after that 1 minute, perfect for sfc enabled install, but for anyone with sfc disabled to begin with, might find it enabled after that minute.I didn't check that. But, I will. I don't know how to check if sfc is disabled. But, if it's possible, I'll find it.
July 20, 200916 yr why u still offer the RC versionWindows 7 is now RTM please modify it my friend :icon_cool:
July 20, 200916 yr why u still offer the RC versionWindows 7 is now RTM please modify it my friend :icon_cool:RTM has not been released officially.Well from what I remember..
July 20, 200916 yr RTM has not been released officially.Well from what I remember..yeah Win 7 is not yet RTM its in the RTM Stage the last Leaked << Warez >> was version 7600.16385some Rumors say its the final version but no confirmation until now so Still Rc is the final build by Microsoft
July 20, 200916 yr yeah Win 7 is not yet RTM its in the RTM Stage the last Leaked << Warez >> was version 7600.16385some Rumors say its the final version but no confirmation until now so Still Rc is the final build by Microsoftahhh Now I get the pictureThanks!
August 13, 200915 yr Author I should have an internet connection by the end of next week. I will try to download the RTM and update this.
September 12, 200915 yr Author updated to 6.1.7600.16385I will create the same files for x64 in a few days.
September 12, 200915 yr updated to 6.1.7600.16385I will create the same files for x64 in a few days.thanks.md5 doesn't match addon.
September 12, 200915 yr Author thanks.md5 doesn't match addon.Sorry, wrong file was posted. Correct file has now been uploaded and md5 corrected.
October 28, 200915 yr This is obsolete...remote desktop v7 for XP is outi just saw your replays in RyanVm.Net and seen the new updates i gonna wait for the other updates better
November 27, 200915 yr This is obsolete...remote desktop v7 for XP is outI've been searching for entire minutes for a v7 addon on both this site and RyanVMs ... anyone got a link? Cheers.
December 5, 201014 yr Hello everyone, no news on a Remote Desktop Client 7 AddOn (silent installer would be useful too) that could be compatible with Server 2003 too? MS didn't updated 2003 client, and 7.0 has significant technical improvements.I'm using it on a daily basis on many Windows 2003 systems, but had to manually extract files, and they work perfectly with every feature.Kind regards!
December 5, 201014 yr Author Hello everyone, no news on a Remote Desktop Client 7 AddOn (silent installer would be useful too) that could be compatible with Server 2003 too? MS didn't updated 2003 client, and 7.0 has significant technical improvements.I'm using it on a daily basis on many Windows 2003 systems, but had to manually extract files, and they work perfectly with every feature.Kind regards!I will update the links as soon as I can find a copy of this files.
December 7, 201014 yr Hello JonnyBoy,This is version 6, right? latest is 7, a lot of improvements, a very wanted one specially on Windows Server 2003.http://www.microsoft.com/downloads/en/details.aspx?FamilyId=72158b4e-b527-45e4-af24-d02938a95683&displaylang=enLinks updated.
