[SOLVED] IE10 langpack not integrated in 1.4.1.22
  • Replies 94
  • Views 30.2k
  • @RicaNeaga: I Kow you wanted to help and I thank you for that but I said multiple times and since the first post that a previous version of WinToolkit can integrate the French IE10 LP just fine, so I
  • Legolash2o
    Legolash2o
    So the problem is because 'IE10 & KB2786081' are not pushed into the prerequisites list? Mooms, what did you do different to that they wan't in the prerequisites list. Did you import the last sess
  • Legolash2o
    Legolash2o
    VirtualBox just finished installing. IE10 menu's were in FRENCH
So the problem is because 'IE10 & KB2786081' are not pushed into the prerequisites list? Mooms, what did you do different to that they wan't in the prerequisites list. Did you import the last session?
I've added a right-click option where you can move updates to and from the prerequisites list.
made a new test with 1.4.1.23 test1.
Started "from scratch" (no import at all)
IE10 still in English, French langpack appears to be integrated but not installed
Below is the last_session.ini
*AIO
#Services
Remote Registry::Disabled
Windows Error Reporting::Disabled
Windows Search::Disabled
#Silent Installs
270312vcredist::;NO;10.77 MB;F:\win7\switchless\270312vcredist.exe;Always Installed
CCleaner_4004064::;NO;3.22 MB;F:\win7\switchless\CCleaner_4004064.exe;Always Installed
DXrt32::;NO;13.04 MB;F:\win7\switchless\DXrt32.exe;Always Installed
firefox_2001_ext::;NO;22.32 MB;F:\win7\switchless\firefox_2001_ext.exe;Always Installed
Flash_ax::;NO;16.34 MB;F:\win7\switchless\Flash_ax.exe;Always Installed
Flash_Plugin::;NO;16.98 MB;F:\win7\switchless\Flash_Plugin.exe;Always Installed
hashchk::;NO;56.00 KB;F:\win7\switchless\hashchk.exe;Always Installed
KB976002-x86::;NO;262.73 KB;F:\win7\switchless\KB976002-x86.msu;Always Installed
KB2533552-x86::;NO;4.07 MB;F:\win7\switchless\KB2533552-x86.msu;Always Installed
KB2592687-x86::;NO;4.35 MB;F:\win7\switchless\KB2592687-x86.msu;Always Installed
rootsupd::;NO;383.63 KB;F:\win7\switchless\rootsupd.exe;Always Installed
SFX_CMDopen::;NO;120.61 KB;F:\win7\switchless\SFX_CMDopen.exe;Always Installed
SFX_Everything_13062b::;NO;526.80 KB;F:\win7\switchless\SFX_Everything_13062b.exe;Always Installed
SFX_klcpf985::;NO;18.69 MB;F:\win7\switchless\SFX_klcpf985.exe;Always Installed
SFX_np2mod::;NO;1.13 MB;F:\win7\switchless\SFX_np2mod.exe;Always Installed
SumatraPDF221::;NO;4.70 MB;F:\win7\switchless\SumatraPDF221.exe;Always Installed
Firefox_default::;NO;95.87 KB;F:\win7\switchless\Firefox_default.exe;Always Installed
utilitaires_sfx::;NO;11.86 MB;F:\win7\switchless\utilitaires_sfx.exe;Always Installed
Winrar420Fr_AiO::;NO;3.03 MB;F:\win7\switchless\Winrar420Fr_AiO.exe;Always Installed
dotNetFx45_x86_x64_Fr::;NO;47.84 MB;F:\win7\switchless\dotNetFx45_x86_x64_Fr.exe;Always Installed
#Tweaks
Show 'Computer' on Desktop
Control Panel View::Large Icons
Disable Desktop Preview [Win7]
Disable Search Online on Unknown File Extensions
Show File Extensions
Show Hidden Files & Folders
Speed-up Access to AVI Media Files
Disable Auto Reboot after installing updates
Enable DVD in Media Player
Enable SSL and TLS
Open NFO files with notepad
Disable Default Browser Check
Disable First Run Customize
Disable Signature checking for EXEs
Disable Warning on Close (Tabs)
IE Homepage::about:blank
Disable Automatic Restart on BSOD
Disable Dr Watson
Disable Windows Error Reporting
tweaks.reg::F:\win7\tweaks.reg
#Updates
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2479943-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2484033-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2488113-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2491683-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2502285-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2503665-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2505438-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2506212-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2506928-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2509553-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2511250-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2511455-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2515325-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2522422-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2529073-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2532531-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2536275-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2536276-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2541014-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2544893-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2545698-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2547666-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2552343-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2560656-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2563227-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2564958-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2570947-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2574819-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2579686-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2584146-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2585542-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2604115-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2619339-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2620704-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2620712-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2621440-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2631813-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2640148-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2644615-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2647753-v4-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2653956-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2654428-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2655992-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2656356-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2656411-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2658846-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2659262-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2660075-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2660649-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2661254-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2667402-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2670838-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2676562-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2677070-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2679255-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2685811-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2685813-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2685939-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2690533-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2691442-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2698365-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2699779-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2705219-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2709630-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2709981-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2712808-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2718704-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2719857-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2719985-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2726535-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2727528-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2729094-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2729452-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2731771-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2732059-v5-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2732487-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2732500-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2735855-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2736233-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2736422-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2739159-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2741355-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2742599-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2743555-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2749655-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2750841-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2753842-v2-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2756822-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2756921-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2757638-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2758857-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2761217-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2763523-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2769369-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2770660-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2773072-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2779562-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2785220-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2786081-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2786400-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2789645-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2790113-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2790655-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-kb2791765-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2799926-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2807986-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2808735-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2813170-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB2813347-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB971033-x86.msu
F:\win7\7SP1_X86_UpdatePack\Windows6.1-KB982018-v3-x86.msu
F:\win7\7SP1_X86_UpdatePack\WUClient-SelfUpdate-ActiveX-x86.cab
F:\win7\7SP1_X86_UpdatePack\WUClient-SelfUpdate-Aux-TopLevel-x86.cab
F:\win7\7SP1_X86_UpdatePack\WUClient-SelfUpdate-Core-TopLevel-x86.cab
F:\win7\7SP1_X86_UpdatePack\z1-IE-Win7.CAB
F:\win7\7SP1_X86_UpdatePack\z2-ielangpack-FRA.CAB
F:\win7\7SP1_X86_UpdatePack\z3-IE-Hyphenation-NEU.MSU
F:\win7\7SP1_X86_UpdatePack\z4-IE-Spelling-NEU.MSU
F:\win7\7SP1_X86_UpdatePack\z5-IE-Hyphenation-FRA.MSU
F:\win7\7SP1_X86_UpdatePack\z6-IE-Spelling-FRA.MSU
F:\win7\7SP1_X86_UpdatePack\z7-IE10-Windows6.1-KB2817183-x86.msu
#Options
Compatibility Check
Create Backups
Delete Silent Installers
Enable CMD
Integrate 'HDC' Drivers (boot.wim)
Integrate 'SCSIADAPTER' Drivers (boot.wim)
Integrate 'SYSTEM' Drivers (boot.wim)
Prepare Drivers
Prompt Addons
Prompt Drivers
Prompt Gadgets
Prompt Silent
Prompt Themes
Prompt Updates
Prompt Wallpapers
Rebuild Image
Show Browse Dialog
Show Duplicates
The whole discussion here was about how IE10 is better integrated last, before IE10 languagepacks and others related, and NOT from the prerequisites. The working build of Win Toolkit that solves mooms problem is an older one that doesn't force IE10 into the prerequisites area.
So maybe you're thinking with a wrong premise / wrong starting argument.
Prequisite files integrated at first (example for Windows 7 x86 SP1):Windows6.1-KB2533623-x86.msuWindows6.1-KB2670838-x86.msuWindows6.1-KB2726535-x86.msuWindows6.1-KB2729094-v2-x86.msuWindows6.1-KB2731771-x86.msuWindows6.1-KB2786081-x86.msu
Some updates for x64?
We can read Inside the file SETUPDOWNLOADLIST.txt the prerequisites updates for IE10 x64 when IE10 file is extracted:
; The following are prerequisites for installing IE
[Prerequisites]
WIN7_SP1=
KB2670838
KB2639308
KB2533623
KB2731771
KB2729094
KB2786081
Yes they are the same prerequisites updates written inside the SETUPDOWNLOADLIST.txt
However we can also read inside this link updates needed:
How to obtain prerequisite updates for Internet Explorer 10 Release Preview that fail to install in Windows 7
However it's missing, for any reason, inside my first list for x86: KB2639308
Update for Windows 7 (KB2639308) (validation needed)
Edited by myselfidem
Will this option be implemented soon? Or have you found a different solution for the languagepacks problem described in this thread?
People are recommending  earlier builds of your app for those having this issue, and I don't think you want this.
Tried a new build with 1.4.1.24: IE10 is still in English.
Not altered the order of prerequisites (on purpose: the default setting should work).
Integrated with this cab (more up-to-date than the one in IE10 exe): http://www.microsoft.com/en-us/download/details.aspx?id=36808
The same integration with 1.4.1.16 is working fine.
Edit: tried a new build, moved IE10 cab out of prerequisites, it is moved at the bottom, if I try to move it up, (because it must be integrated before the langpack) I have an error:
text of the error:
Exception:
Form: frmAllInOne (False)
Status:
Anti-Virus: False
Version: 1.4.1.24
Unhandled Exception: Object reference not set to an instance of an object.
StackTrace:    at (Object )
   at A.
.(Object , EventArgs )
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
InnerException:
Source: WinToolkit
TargetSite: SelectedListViewItemCollection (System.Object)
Data: System.Collections.ListDictionaryInternal
Form History: frmStartup, frmToolsManager, frmAntiVirus, frmWIMManager, frmAllInOne, frmToolsManager, frmWIMManager, frmAllInOne, frmTweaks, frmTweaks, frmError,
Open Forms: frmStartup, frmAllInOne,
Also, if I try to add IE10 French exe, I have this error:
FYI, these two KB aren't really needed for integrating IE10.
We hope so Legolash, and thank you.
Rq: is WinToolkit141-25_Test1 the test build you are talking about and the recent one ?
Edited by lib9
Now results, unfortunately no change IE10 is in english :
Log :
*AIO
#Updates
C:\DISMTOOL\updates\WUClient-SelfUpdate-ActiveX-x86.cab
C:\DISMTOOL\updates\WUClient-SelfUpdate-Aux-TopLevel-x86.cab
C:\DISMTOOL\updates\WUClient-SelfUpdate-Core-TopLevel-x86.cab
C:\DISMTOOL\updates\Windows6.1-KB2574819-x86.msu
C:\DISMTOOL\updates\z2-ielangpack-FRA.CAB
C:\DISMTOOL\updates\Windows6.1-KB971033-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB982018-v3-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2479943-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2491683-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2503665-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2506212-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2506928-v2-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2509553-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2511455-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2515325-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2529073-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2532531-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2536275-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2536276-v2-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2541014-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2544893-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2545698-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2547666-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2552343-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2560656-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2563227-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2564958-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2570947-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2670838-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2579686-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2584146-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2585542-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2604115-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2619339-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2620704-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2621440-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2631813-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2640148-v2-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2644615-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2647753-v4-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2653956-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2654428-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2655992-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2656356-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2656411-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2658846-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2659262-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2660075-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2660649-x86.msu
C:\DISMTOOL\updates\Windows6.1-kb2661254-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2667402-v2-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2729094-v2-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2676562-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2679255-v2-x86.msu
C:\DISMTOOL\updates\Windows6.1-kb2685811-x86.msu
C:\DISMTOOL\updates\Windows6.1-kb2685813-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2685939-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2690533-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2691442-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2698365-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2699779-v2-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2705219-v2-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2709630-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2709981-v2-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2712808-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2718704-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2719857-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2719985-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2726535-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2727528-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2786081-x86.msu
C:\DISMTOOL\updates\Windows6.1-kb2729452-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2732059-v5-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2732487-v2-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2732500-v2-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2736422-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2742599-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2743555-x86.msu
C:\DISMTOOL\updates\Windows6.1-kb2749655-x86.msu
C:\DISMTOOL\updates\Windows6.1-kb2750841-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2753842-v2-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2756921-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2757638-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2758857-x86.msu
C:\DISMTOOL\updates\Windows6.1-kb2761217-x86.msu
C:\DISMTOOL\updates\Windows6.1-kb2763523-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2769369-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2770660-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2773072-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2779562-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2785220-x86.msu
C:\DISMTOOL\updates\z1- IE10-Windows6.1-KB2718695-x86.cab
C:\DISMTOOL\updates\Windows6.1-KB2786400-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2789645-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2790113-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2790655-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2798162-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2799926-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2804579-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2807986-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2813170-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2813347-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2813956-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2820197-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2820331-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2829361-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2830290-x86.msu
C:\DISMTOOL\updates\Windows6.1-KB2840149-x86.msu
C:\DISMTOOL\updates\z3-IE-Hyphenation-NEU.MSU
C:\DISMTOOL\updates\z4-IE-Spelling-NEU.MSU
C:\DISMTOOL\updates\z5-IE-Hyphenation-FRA.MSU
C:\DISMTOOL\updates\z6-IE-Spelling-FRA.MSU
#Options
Compatibility Check
Create Backups
Enable CMD
Prepare Drivers
Prompt Addons
Prompt Drivers
Prompt Gadgets
Prompt Silent
Prompt Themes
Prompt Updates
Prompt Wallpapers
Rebuild Image
Show Browse Dialog
Show Duplicates
langpack goes in integration before IE10 and BTW nothing have been moved no alteration at all.
