vLite replacement?
seems nice but
it's a 190 mb too big what does it contain
i gonna download and see
It hangs if u have more than 7 images on DVD and if only one too. New version is in pipeline having fixes and approx 10 mb in size. Just try to use image from DVD drive.
Mine won't even launch
well i read that there would be a version 1.03 it would be 6 mb
and it should have some of that bugs fixed so i would wait for that version
Mardnes that there will be a new version that Nuhi vlite or already working in the new version of vLite to be compatible with windows 7?
From Nuhi no
He stopped that project
And i didn't read that there would be any versions.
I think flash.ocx file missing in ur computer. Register flash.ocx then it works fine.
Thanks Jatin, I ill try that program at a later date, I really need to get alot of XP stuff done.
hi, y so big?!
cheers james
the size is duo to Flash and Video components
i will wait for next version it would be 6 mb (that what the creator said)
and it would have more bug fixes so i would wait
  • 4 weeks later...
I think it's an Awesome program [2 things] don't work
shell32 replacement Drivers
[Error message hangs up on the 2 I mention] wineplay.exe
these are the that I used for windows 7 x64 besides those 3
It would be nice if they can limit what you need to run the program with
It would also be nice if it had where you can added service pack also
* DOT NET Framework 3.5
* Adobe Flash Player ActiveX
* VMware Workstation 7.0 or
Virtual PC (For testing your customized OS virtually)
Edited by MBrys331
