Posted April 23, 201213 yr As you may have noticed i have not worked on Win Toolkit in a while, this is because i had 3 essays to do and now i'm revising for a difficult maths exam in May which means i will not be able to work on WT until that's over, however after that there is 3-4 months with no University work what-so-ever.However, i am retriever lots of error logs which i can work through once i start again and i will reply to peoples topics also then.Sorry for any inconvenience.P.S. In case you're wondering the exam is the 23rd May and will be revising completely until then. University is my #1 priority!
April 23, 201213 yr I'm sure I speak for everyone when I say we wish the best of luck on your exams and we all understand where your priorities lie.
April 24, 201213 yr we all wish you the best of luck in exams lego.good things come to those that wait patiently.university work must come first.agree with compstuff win tookit can wait.
April 27, 201213 yr Education is good. It just means you do not always have the time for stuff on the side. We understand. Best of "luck" (or knowledge) on those tests.
May 9, 201213 yr Thanks for the quick update and hope all is going well even though I'm sure it's very tough... Best of Luck!!!
May 23, 201213 yr Author So glad that exam is all over and done with, anyways i'm currently going through all of the error logs removing duplicates and will start fixing bugs.In other words..... I'm back Edited May 23, 201213 yr by Legolash2o
May 23, 201213 yr Author Thanks, just as a warning though.... It may take a while to reply to everything everyone has posted.
May 26, 201213 yr Author Just an update: Still sorting my error logs (grouping duplicates), they're quite a lot but hopefully I will start coding soon.
May 26, 201213 yr Of course we're all selfishly hoping you are planning to take the summer off from University to be able to devote yourself to more important things such as Win Toolkit. Cheers and Regards
May 26, 201213 yr I would recommend Legolash2o to take a week off and get drunk with friends after exams. Simply to cool down the CPU core ;P ;D
