Whats the difference between MCRip & Solor Hotfixs?
Hello I wanted to know what's the difference between MCRip & Solor Hotfixs?
For Windows Updates
If I have Service Pack 1
Can you intergrade MCRIP or Solor Hotfixs?
Thanks....
ok so i re downloaded the mcrip ones and it put everything i had into old and downloaded about 300 new ones
does that mean i dont need the old ones and only use the ones it has downloaded..?
