[Editable] Vista Firefox 2.0.0.14 (April 16-08)
Editable Mozilla Firefox 2.0.0.14
Info: Editable Mozilla Firefox installer with 3 Vista themes: Aerofox, Ultimatefox and Vistafox included.
Also Includes Mozilla Flash plugin installer, Shockwave plugin, Windows Genuine Advantage plugin, Office Genuine Advantage plugin and Windows Media Player plugin (includes a couple of extra search plugins)
tabdownload.png Updated April 16-2008
MD5: 36285D1995BEB01FC6DB21FB45BEDF92
Website: http://www.mozilla.com/en-US/
Changelog:
4-16-08
- Updated v2.0.0.14
- Updated Flash 9.0.124.0
- Added Live Gallery - Sidebar search plugin
3-26-08
- Updated v2.0.0.13
- Updated WGA, OGA and Shockwave plugins
- Live Search is now the default search engine
2-08-08
- Updated v2.0.0.12
- Meged Flash and Firefox installer into one
12-04-07
- Updated Flash 9.0.115.0
11-30-07
- Updated v2.0.0.11
11-27-07
- Updated v2.0.0.10
11-02-07
- Updated v2.0.0.9
10-19-07
- Updated v2.0.0.8
- Installer is now fully customizable
9-20-07
- Updated v2.0.0.7
- Added 3 Firefox Vista themes (Vistafox is set by default)
Editing Instructions
You can customize the installer any way you like by adding your favorite Extensions, Bookmarks and Search Plugins
- Right click on FF.exe and choose Open with WinRAR
- You may now drag-and-drop your Extensions into the "nonlocalized\extensions" sub-dir
Other Information
Search Plugins directory (add/delete search plugins)
localized\searchplugins
Bookmarks directory (backup bookmarks.html and replace the default one)
localized\defaults\profile
Default Theme
Edit "localized\defaults\profile\prefs.js" (Tip: copy and paste line from your current prefs.js)
user_pref("general.skins.selectedSkin", "Vistafox");
  • Replies 112
  • Views 57.3k
hi ricks
this is the best internet browser, except for safari (maybe for windows in final release) which is in beta stage.
please update this great addon with the best firefox plugins which are:
adblock plus
adblock filterset.G updater
cooliris preview
undo close tabs button
stealther
ie tab
fission (great plugin)
update notifier
fasterfox
download them all, or maybe some other one you would recommend
and please keep your already integrated plugins there as well as they are a must have
and also if you can please tell me how you made firefox with your own plugins already integrated.
please reply back
thank you
Hi rick!
You must know that integrating of the Windows Genuine Advantage plugin (I think office also) is not working. Its protected. You need also the right reg entries (which I don't know, I'm trying to find that out).
If you installer yours firefox on a clean pc everything will be nice. Except if you need the Genuine plugin on the Microsoft site. MS is saying you haven't installed it yet. Ok you download it and you run the installer. The fun started. Installer say: The genuine plugin is currently installed. So then you can't install it but also you can't remove it. Problems!
So I suggest: remove them :icon_rolleyes:
Then: Firefox say that its better to use the -silent install switch. For what I don't know.
Edited by Inferi0r
Hi rick!
Has anyone else confirmed this? Or is this no longer an issue?
Hi Rick. I'm not seeing any themes, and I've tried it a couple of different times. Integrated using both Nlite and RyanVM integrator. Am I missing something, or misinterpreting something? Thanks!
Edit: To clarify, I've integrated using both Nlite and Ryan's, not at the same time :)
Edited by Steve
Interesting. I am always futzing with my pc, so I keep my firefox profile on my storage drive. I started a new profile, and the themes showed up. However, when I install a search toolbar, such as ask or google, I can't get it to show text with the buttons, in any theme except the default firefox theme.
It's been a while since I used themes, but I don't recall that ever happening before.
Edited by Steve
Can you please tell me how you created this add-on and where did you find the plug-ins. I am very keen to learn how you created this add-on. Thanks in advance.
