August 15, 200719 yr QT Address BarMake your XP addressbar more handy in Vistih style DOWNLOAD@ 169.19 KBMD5: 14FAD30FAF24B3F9D5D5D199B1033F37Note: It need to be enabled via explorer shell: View\Toolbars\QT...Changelog: 5-October-07 - Update to version 0.9.5. Addon now instals via RunOnce during first logon. 15-August-07 - first release...includes add/remove entries. Edited November 6, 200719 yr by Gorki
August 15, 200719 yr Author Thanks for the link runningfool. I will see what can I do...in couple of days...cause I already started working on some other (Vistish) addon... :beerchug:
August 15, 200719 yr no problem, gorki...i just love these vista-ish addons that require little or no memory :thumb_yello: . keep up the great work!
August 15, 200719 yr Styler 1.401 wonderfull Styler 1.401 addon absent forum ?Styler 1.401 addon please :sweatingbullets: Styler 1.401 download:http://www.crystalxp.net/galerie/en.id.551...lorer-tools.htmstyler vista themeshttp://rapidshare.com/files/49187200/Frost.rar.html
August 15, 200719 yr Styler 1.401 wonderfull Styler 1.401 addon absent forum ?Styler 1.401 addon please :sweatingbullets: Styler 1.401 download:http://www.crystalxp.net/galerie/en.id.551...lorer-tools.htmstyler vista themeshttp://rapidshare.com/files/49187200/Frost.rar.htmlOK I have some time let me see how I can make it.
August 17, 200719 yr Author You only include the setup somewhere, no installation, doesn't work!No mate you have to run QT Address Bar via Start/Utilities to install/activate program. Then you have to enable it in My Computer View/Toolbars.
August 19, 200719 yr No mate you have to run QT Address Bar via Start/Utilities to install/activate program. Then you have to enable it in My Computer View/Toolbars.So what's the point of this addon if you have to install it yourself?
August 19, 200719 yr So what's the point of this addon if you have to install it yourself?The reason this addon is made this way is it needs .Net 2.0 installed before you even try to install the address bar mod (this guarantees it)This way you can install and uninstall it.
August 23, 200719 yr OK I have some time let me see how I can make it.That would be nice, if you can make the OT Adress Bar "compatible" with the Styler. But i think that's difficult =/
August 23, 200719 yr Hi Gorki,What switches did you use to make the installer silent? I am trying to make an addon for QTToolbar and I haven't found a way... Thanks!
August 23, 200719 yr Author Hi Gorki,What switches did you use to make the installer silent? I am trying to make an addon for QTToolbar and I haven't found a way... Thanks!I did not use any switches as it's named as true addon not svcpack addon. You should also know that this applications like QT Toolbar,QTAdressbar,Styler,etc... require different approach when making it as addon. Generally RunOnceEx should work for those.And for the note..I'm working on improving QT Address Bar addon so It won't be needed any user interference to activate it.
August 24, 200719 yr iits easy to make it unattended,with an autoit script that is...and u need a reg to add it to ure toolbar,cuz ull ahve to r clik and add it ure self.
September 3, 200719 yr I like.. it looks like Vista.. as well as the functionality!!! .. Thanks :thumbsup_anim:
September 11, 200719 yr A new version has been released; could this addon also include the QT Tab Bar? Both have been updated. Thanks!
September 15, 200719 yr Is there a place where the settings are saved? Like the place where the bar is placed and that the standard adress bar is unchecked.And is there a svpack addon for this?
September 15, 200719 yr Is there a place where the settings are saved? Like the place where the bar is placed and that the standard adress bar is unchecked.HKCU,"Software\Microsoft\Internet Explorer\Toolbar\ShellBrowser","ITBarLayout"And is there a svpack addon for this?Nope, the reason is it might not install. It requires .Net framework 2.0 be installed first
