May 26, 200916 yr Please note that this add-on requires .NET Framework v2.0 in order to operate. Failure to install it will result in no navigation buttons or address bar by default, however, it will show up once .NET is installed.QT Address Bar 0.9.6Replaces the standard address bar to make your XP addressbar more handy, like in Vista.QTTab Bar v1.2.2.1Adds tabs to your Windows Explorer and replaces the standard buttons with the QT Standard Buttons.file: Doug_QTBar_AddOn_v2.0.7zFile Size: 941kbMD5 Hash: 211B1BF6E22BCF8E6DC2E682B5566321ChangeLog:v1.0 = Initial release of add-onv1.1 = Fixed entries to add correct filenames to the XP source.v2.0 = Added uninstaller so it is now removable.NOTICE: I've corrected the incorrect version numbers in the topic title by swapping the 2 version numbers around. Sorry if this lead to confusion for anybody!QT Address Bar 0.9.6 ONLYmooms modified my original add-on to remove the QT Tab Bar portion and added a working uninstaller to the add-on! Thank you, mooms, ricktendo64, and Kelsenellenelvian!!!Uninstaller Presentfile: QT_AddressBar_inf_AddOn_v2.2.rarFile Size: 117kbMD5 Hash: B7BEFB40E8834F461F5857530036FB6AWith the Help of ricktendo64, the inf now delete the files on next reboot.No more need to kill explorer, much better uninstall !Still one glitch : Original XP address bar will be restored only for the user who had launched the uninstall.Other user(s) will have to manually re-enable the XP address bar after uninstall of QTAdressBar.It's a HKCU key, so i can't do better. (tried HKLM and HKCR, no go)No Uninstaller Presentfile: QT_AddressBar_inf_AddOn_v1.2.rarFile Size: 116kbMD5 Hash: CD248071B17DE01200BC1E7FA8B94980I have also updated the non-uninstallable version, now the inf and pnf files are deleted on reboot and sysoc.inf is cleaned after install.The install is flawless now.
May 29, 200916 yr want to try this QTBar true addon in my new xp project,but i found you used the different name in the archive,i'm afraid this would destroy the whole inf installation
May 30, 200916 yr Author OOPS! You're right, it would break installs! I've uploaded v1.1 with the problem fixed!
June 6, 200916 yr must be something to do with firefox...i tryed it with IE and it worked fine..Yes buddy you are right bcoz i also got the same error message in Opera, but also tried internet explorer still error.Error in Opera.Error in Internet Explorer. Edited June 6, 200916 yr by MANIKANT.S.GUPTA
June 7, 200916 yr Author Try this link: Doug_QTBar_AddOn_v1.1.7z. Hopefully this one will work for you.... If that fails, try this: Doug_QTBar_AddOn_v1.1.7z at 4shared.com.... Added the mirror to first post.
June 7, 200916 yr Try this link: Doug_QTBar_AddOn_v1.1.7z. Hopefully this one will work for you.... If that fails, try this: Doug_QTBar_AddOn_v1.1.7z at 4shared.com.... Added the mirror to first post. Thanks, These Links Worked.
December 14, 200916 yr This addon is great, but it cause my unattended to semi-fail (no themes, no custom tweaks applied, etc....)!i have found the reason in the file Entries_QT_Bar.ini:builddate=2009/05/23description=QTBar & QT Address Bar Add-Onlanguage=English (United States)title=QT_Tab Add-Onversion=1.1website=[sysoc]QT_Tab=ocgen.dll,OcEntry,QT_Tab.inf,HIDE,7[dosnet_files]d1,QT_Tab.infd1,QT_Tab.cab[txtsetup_files]QT_Tab.cab = 100,,,,,,_x,,3,3QT_Tab.inf = 100,,,,,,,20,0,0[i386_compress]rvmtemp\extracted\QT_Tab.infit should be:[general]builddate=2009/05/23description=QTBar & QT Address Bar Add-Onlanguage=English (United States)title=QT_Tab Add-Onversion=1.1website=[sysoc]QT_Tab=ocgen.dll,OcEntry,QT_Bar.inf,HIDE,7[dosnet_files]d1,QT_Bar.infd1,QT_Bar.CAB[txtsetup_files]QT_Bar.cab = 100,,,,,,_x,,3,3QT_Bar.inf = 100,,,,,,,20,0,0[i386_compress]rvmtemp\extracted\QT_Bar.infI'm surprised that nobody have reported that!i have uploaded a corriged version: Doug_QTBar_AddOn_v1.1.rarMD5: 321b7f0a3b1a1eefcfd5637e21b55580size: 935 kb Edited December 14, 200916 yr by mooms
January 23, 201016 yr Please can you help me to keep these settings after unattended installation?edit: found this key:HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbarand was looking into subfolders.If I integrate these settings will that work? Edited January 23, 201016 yr by stsaerox
March 14, 201016 yr Author Updated add-on to v2.0 and added the ability to uninstall the add-on via Add/Remove Programs.mooms: I'm sorry for the VERY late reply! I've fixed the add-on so that it will integrate properly. It's uploaded now.stsaerox: I'm sorry for the late reply. There are two keys that I'm aware of that affect Windows Explorer. These keys are:(1) Key: HKCUSOFTWAREMicrosoftInternet ExplorerToolbar, Value: ITBarLayout(2) Key: HKCUSOFTWAREMicrosoftInternet ExplorerToolbar, Value: {710EB7A1-45ED-11D0-924A-0020AFC7AC4D}Exporting these two keys and importing them into the add-on should preserve those settings.
August 25, 201015 yr Author anyone have made a backup of v2.0 ? if so please set a mirror! :doh: I wasn't aware that the download link wasn't working. I've fixed it so that the file is now downloadable.... Really sorry about that!
August 27, 201015 yr :doh: I wasn't aware that the download link wasn't working. I've fixed it so that the file is now downloadable.... Really sorry about that!I have testedv2.0, uninstallation did not work, i stick with v1.1 as it works well.Thank you anyway !
July 4, 201114 yr Do you have QT Address Bar only?.. I'm having problems with the QT standard buttons when using other windows themes the standard buttons where missing.. and i don't like QT Tab Bar..
July 10, 201114 yr Author Do you have QT Address Bar only?.. I'm having problems with the QT standard buttons when using other windows themes the standard buttons where missing.. and i don't like QT Tab Bar..I'm sorry. I don't have QT Tab Bar by itself. I will try to build an add-on in the next few days, but it's been a long time since I built this add-on.... It may take my a while....
August 5, 201114 yr Do you have QT Address Bar only?.. I'm having problems with the QT standard buttons when using other windows themes the standard buttons where missing.. and i don't like QT Tab Bar..Because i don't need QT Tab Bar me neither, i have made an addon with QT Address Bar only (based on doug's addon v1.1). Here it is No uninstall but not really needed.Notice how small it is without QT Tab Bar. QT AddressBar_inf_AddOn_v1.1.rar Edited August 5, 201114 yr by mooms
October 10, 201114 yr Author Because i don't need QT Tab Bar me neither, i have made an addon with QT Address Bar only (based on doug's addon v1.1). Here it is No uninstall but not really needed.Notice how small it is without QT Tab Bar. Wow! Man, I've been really behind the curve lately.... Would you mind if I posted it on XPtsp.com?
October 11, 201114 yr No, it is ok dougie ! It's indeed based on your work so....If i found time and motivation i will add uninstallation, but is it really needed ? Edited October 11, 201114 yr by mooms
October 15, 201114 yr Author No, it is ok dougie ! It's indeed based on your work so....If i found time and motivation i will add uninstallation, but is it really needed ?Nah, the ability to uninstall it would be nice, but it's not necessary at the moment. But if you want to build an uninstaller for this add-on, feel free to do so! Btw, thanks for permission to post it!
