UpdateCache Test
Hello I was wondering if anyone could download this file and put it in the same folder as WinToolkit.exe:
http://wincert.net/leli55PK/updateCache.db [Right-click > Save As]
I'm hoping it adds updates to AIO-Integrator quicker. The full version is already in v2.x but I've managed to backport some of it to v1.x
My Results [565 Updates]
No UpdateCache.db: 1m 51s
UpdateCache.db: 7 seconds
1585.71% speed increase LOL!!
v2.x
The biggest difference with the v2.x version is that it's adds new updated not into the cache to the cache so it grows and only the first time you add the update it runs at the normal standard speed.
v1.x
The version in v1.x just reads from the database and doesn't grow.
THANKS.
On my creeky old WinXP system with 535 updates (611 preset items):
without db: 2 minutes 37 seconds
with db: 18 seconds
awesome!
There seems to be a small bug with this. When I load the attached preset with UpdateCache.db in the same folder as Wintookit.exe, the RSAT package Windows6.1-KB958830-x64-RefreshPkg.msu doesn't get loaded. I am integrating Windows 7 64 bit. When I remove UpdateCache.db, it loads fine. This is with WinToolkit 1.5.2.15 running under Windows XP. There is no error message when loading from the preset, or adding via "Add Updates + Subfolders" options. When I add that one update via "Add Updates", I get this error message:
Title: 1 update(s) skipped.
ErrType: Error
Description: More information is available by clicking the '>> Details' button.
Exception:
Invalid architecture: 'F:\WHD\Updates\Windows7-x64\Extra\RSAT\Windows6.1-KB958830-x64-RefreshPkg.msu'
Thanks,
Clark.
x64 20141023 1.ini
ok so do I rename the extension from .txt to.db?? The name of the file is updatecache.txt. its 490k.
if not, solution?
regards...
Edited by pennsylvaniaron
