UltraISO
Handle CD and DVD Images with Ease!
Website: http://www.ezbsystems.com/ultraiso/
Size: 2.38 MB (2,502,800 bytes)
MD5: 8884f25bffca151fe384e7c9a4e2bedb
Change
07/11/2009 update to version9.3.5.2716
13/02/2009 Update registration and language using updateinis directive (Must thanks DaRk MaDnEsS!)
11/02/2009 update to version9.3.3.2685
12/06/2008 update to version9.3.2.2656
10/16/2008 update to v9.3.1.2633
08/17/2008 version 9.3.0.2612
How to add registration infomation and change your language
Extract 7z achive,open ultraiso.inf,insert your informations at 'strings' section as below
[Strings]
Name1="registration name" ;;;<---add your user name
SN1="registration code" ;;;<---add your serial number
LNG1="English" ;;;<--add your language according to the language submenu string
Edited by bjfrog
This version of UltraISO supports .daa and .uif
Revsion History
UltraISO Premium 9.0 (February 28, 2008)
+) Enhanced ISO CD/DVD image processing core, can open, convert and burn many compressed ISO image format including ISZ, DMG, DAA and UIF
Just to put peoples minds at ease and to stop you installing more apps than you actually need ;)
problem in ultraiso its not able to open .uif and .daa
This is not a problem,just seclect .uif and .daa and associate them with UltraISO
Click OPTIONS menu select CONFIGURATION submenu then click INREGRATION tab ,
See?
More details you can check UltraISO manul by cklick UltraISO Help shortcut.
BTW default only associate with .iso .bin .isz
Edited by bjfrog
Version 9.30 new features :)
UltraISO Premium 9.3 (July 25, 2008)
+) Enhanced U+ boot technology (USB-HDD+/USB-ZIP+), improves boot
compatibility and reliability
+) New "Xpress Boot" feature set, can keep disk format on creating
bootable USB flash drive's(UFD's)(Xpress Write) and change master boot
record(MBR)/boot sector of UFD's with ease
+) Can make ISO image from emulated USB-CDROM drive's
+) Can save multi-segment .ISO/.NRG images (above 4GB) in FAT32 volume
+) Can use ultraiso.ini to save/load configuration (install="-1")
*) Keeps graphics menu on writing isolinux/syslinux based bootable UFD's
*) Some minor improvements and bug fixes
he mustn't have red "Can preset your registration and language ID at string section in INF file
@Bober,Thanks ,I should give a explanation
i have done every thing you have suggested but no luck say a file type not recognized but it opens fine i power iso
OK let me know this registry key value
HKCR,".daa",,0x0,"UltraISO or PowerISO?"
and reopen Options menu select Configuration submenu ,click Integraton tab check .daa selected or not
I think you should find what cause that :)
it work fine to me included .daa files,
UltraISO has many amazing features that PowerISO dont have.
Small bug: Uninstall only show up in the remove panel if 'show updates' box is checked?
Thanks for the nice addon,
Czar
@czartj : you are welcome
the uninstallation registry section come from my 2in1 addon (ultraiso and ezboot) ,personally I like put the simliar programs together,so it work fine the way they are,
you can delete below two lines in ultraiso.inf to make uninstallation work in normal way
via extract 7z archive edit ultraiso.inf and repack
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\UltraISO_is1","ParentDisplayName",0,"EZ Systems,Inc"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\UltraISO_is1","ParentKeyName",0,"EZSystem"
Edited by bjfrog
update to version 9.3.3.2685
changes in new version
UltraISO Premium 9.33 (February 11, 2009)
+) Can open, view and extract files from XBOX360 ISO images
and non copy-protected XBOX360 DVD's
+) Supports mounting UDF DVD images on Windows Vista/Windows 7 Beta1 (ISODrive)
+) Saves newly detected media capacity
*) Improveed performance for editing bootable ISO's with large boot image file
*) Can detect and use Nero 9 as default burning software
*) Fixed a compatible problem with Ashampoo burning package
*) Fixed a bug with converting some PlayStation CD images in MDS/MDF format
thanks for the update.is it possible to update this too.thanks
you are welcome and nice to see you r interesting in this one ,updated ,enjoy!
Hi bjfrog
i found a way to allow the ultra iso to register using the orignal UserName and Register Code
using An Ini File Named uikey.ini
What in the Ini
UserName='XXXXX'
Registration='XXXX-XXXX-XXXX-XXXX'
you can add this command to the Inf
UpdateInis =uikey.Ini
[uikey.Ini]
%ProgramDir%\uikey.Ini,,,"UserName='%User%"
%ProgramDir%\uikey.Ini,,,"Registration='%Reg%"
[strings]
User="" ;;;;Add the User Name
Reg="" ;;;;Add The Registration Code
hope you like the trick
but it won't save it to the Registery for your info
Edited by DaRk MaDnEsS
Hi bjfrog
hey DaRk MaDnEsS,this is great,thanks for the cool trick :thumbsup_anim: :giveheart:
i know updateinis is very usefull directive for program settings but this is the first i met using it on program registration,its awesome,so far havent figured out how does it work,as you said it dont depend on registry entries,I'll give it more try and learning,thanks a lot .
BTW I updated the regstration in this new method.
well i already found that one while i was searching for some other stuff
i opened the Fourm Page by mistake
and i found that this trick was for Using in flash drive it would be nice as a portable not using any registry
and i found as well using that unikey that you can change lang
Language='Deutsch'
that all what i found and hope you understand about UpdateInis and if you got stuck in any thing i would be happy to help
Please sign in to comment
Sign In Now
