Let's ping again!
Hi guys,
I need a favor from all of you who opened this topic. We'll have to test ping response times on two servers and I need your help on this.
So here's what you should do..
Open a command prompt (Start-->Run-->CMD+Enter)
Type ping 69.73.170.7, write down this info: Minimum = xx ms, Maximum = xx ms, Average = xx ms
Repeat the action for the second address
Type ping 209.172.60.147, write down this info: Minimum = xx ms, Maximum = xx ms, Average = xx ms
Check and paste your results here.
Please help us check the server latency in this way.
Thank you all.
Server 69.73.170.7
Ping statistics for 69.73.170.7:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 162ms, Maximum = 168ms, Average = 165ms
Server 209.172.60.147
Ping statistics for 209.172.60.147:
Minimum = 170ms, Maximum = 173ms, Average = 171ms
@agli
Are you satisfied with the site overall speed? Did you notice any difference with this new host?
I have 768 kbit adsl and in the apartment powerline adapter on current network and directly to the router.
Minimum = 234ms, Maximum = 413ms, Average = 315ms
Minimum = 214ms, Maximum = 301ms, Average = 267ms
There ya go :)
Edited by Mr.Thunderbird
Minimum = 13ms, Maximum = 15ms, Average = 14ms
Minimum = 48ms, Maximum = -35ms, Average = 28ms
OMG, Jonnyboy, servers are probably next door to you :D
N1K see this its not good? why
C:\Users\Ricardo>ping 69.73.170.7
Pinging 69.73.170.7 with 32 bytes of data:
Reply from 69.73.170.7: bytes=32 time=50ms TTL=57
Reply from 69.73.170.7: bytes=32 time=48ms TTL=57
Reply from 69.73.170.7: bytes=32 time=49ms TTL=57
Reply from 69.73.170.7: bytes=32 time=55ms TTL=57
Minimum = 48ms, Maximum = 55ms, Average = 50ms
C:\Users\Ricardo>ping 209.172.60.147
Pinging 209.172.60.147 with 32 bytes of data:
Reply from 209.172.60.147: bytes=32 time=84ms TTL=45
Reply from 209.172.60.147: bytes=32 time=75ms TTL=45
Reply from 209.172.60.147: bytes=32 time=80ms TTL=45
Reply from 209.172.60.147: bytes=32 time=82ms TTL=45
Minimum = 75ms, Maximum = 84ms, Average = 80ms
N1K my results
Minimum = 186ms, Maximum = 444ms, Average = 365ms
Minimum = 231ms, Maximum = 457ms, Average = 351ms
Pretty good!
Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Minimum = 29ms, Maximum = 1200ms, Average = 75ms
Minimum = 46ms, Maximum = 277ms, Average = 90ms
No issues with speed at this time. Very quick.
Edited by war59312
I had to try several times before I got a non-negative number. I kept saying WTF, this can't be right!
Reply from 209.172.60.147: bytes=32 time=-91ms TTL=46
Reply from 209.172.60.147: bytes=32 time=-92ms TTL=46
Reply from 209.172.60.147: bytes=32 time=-83ms TTL=46
Minimum = -92ms, Maximum = -83ms, Average = 1073741734ms
Edited by Jonnyboy
