April 13, 201015 yr I will try and push this higher. This is after the 1st night of having this 555BE.
April 13, 201015 yr I don't understand the use of it, you're really pushing it, until you see the smoke
April 13, 201015 yr Author I don't understand the use of it, you're really pushing it, until you see the smoke I see a difference in performance and my temps get no higher than 40C. I also wanted to hit the 4GHZ mark. I will see what I can do with it as a TRI and QUAD also.
April 13, 201015 yr I think a processor can successfully overclock to at least 40%. I m using Intel dual core E200 2.2 Ghz @ 3.1 Ghz with no pain.
April 13, 201015 yr Well I could overclock my Core i5, but I just don't trust that Intel stock cooler. I will have to invest in better and more silent cooler like Scythe Zipang2, before doing any overclocking.
April 13, 201015 yr Author Well I could overclock my Core i5, but I just don't trust that Intel stock cooler. I will have to invest in better and more silent cooler like Scythe Zipang2, before doing any overclocking.Yeah, I have that Vendetta. I would like to get a better one but maybe at a later date. I just primed for 2 hours with X4@3.5. I am going to clock it higher since the temps were fine. So yes, I got a 555BE that runs like a 965. :thumbsup_anim:
April 13, 201015 yr Welcome to 4GHz club :thumbsup_anim: Testing with LINX 20 loops is strongly recommended to be sure, that Your OC is stable :icon_cool:
April 13, 201015 yr Author Welcome to 4GHz club :thumbsup_anim: Testing with LINX 20 loops is strongly recommended to be sure, that Your OC is stable :icon_cool:Is that better than OCCT. I will be testing my X4@3.5 tonight.
April 16, 201015 yr Check what these guys did with Ati Radeon card http://www.wincert.net/news/hardware/2030-asus-radeon-hd-5870-graphics-card-reaches-15ghz-clock-speed.html
April 16, 201015 yr Author Check what these guys did with Ati Radeon card http://www.wincert.n...lock-speed.htmlThat is insane.I was drinking most of the day yesterday so I never updated my 555BE testing. I have it stable as a Quad@3.5 with 1.4v.
April 17, 201015 yr i overclocked 2ghz processor to 2.10 and it frequently got overheated and restarted automatically now back at 2ghz.
April 17, 201015 yr Author i overclocked 2ghz processor to 2.10 and it frequently got overheated and restarted automatically now back at 2ghz.What CPU was that? That much of a jump shouldn't even cause a change it heat.
April 17, 201015 yr What CPU was that? That much of a jump shouldn't even cause a change it heat.Agreed, at which temperature PC restarted? Are you using stock cooler?
April 17, 201015 yr Author Agreed, at which temperature PC restarted? Are you using stock cooler?Like N1K said. Most CPU's can be upped 100-300mhz on a stock cooler. Edited April 17, 201015 yr by LUZR4LIFE
