Posted October 17, 201212 yr HiSilent installers are not executed during install with Win7 SP1 Pro_x86 after using 140_76.
October 17, 201212 yr Need a bit more info. Do you keep your installation media/usb plugged in until you see the desktop? Last session.ini? Any error messages?
October 17, 201212 yr Yep, v76 is yet again defective regarding silent installers. NONE of them work after integration - NONE are installed during first boot. You can try it Lego for yourself with ANY silent installer, I don't think further details are needed.
October 18, 201212 yr I can confirm the issue: no silent-SFX, no tweaks, only AddOn.And:if the "old" settings.txt" remains in the folder, a "mix" of Temp-folder follows and temp files are written in WinToolkit (Mount), WinToolkit_Temp (IE9 LP, folders "clinst" and AddOn), but ALL the "extract-works" are done in Windows-Temp; here it's better to delete the "old" settings.txt.Regards, Thiersee
October 18, 201212 yr Tweaks are working fine for me, I've just fixed SFX and the whole WinToolkit_Temp with addons, releasing now...UPD: Released!
October 18, 201212 yr Tweaks are working fine for me, I've just fixed SFX and the whole WinToolkit_Temp with addons, releasing now...Ok, tweaks are working, it was my mistake .The issue with extracting into Windows temp-folder is still present, look at the folder's time of "clnst" (2nd picture) and of the extracted folders "9C73FFF2-xxxxxx" (1st picture)in Windows-Temp.The folder "cInst" is always empty; this behavior seems to appear only for "Updates+Languages". Edited October 18, 201212 yr by Thiersee
October 18, 201212 yr I've added some better cleaning, but as long as integration works then it should be fine...DISM/PKGMGR makes the "9C73FFF2-xxxxxx" folders...
October 18, 201212 yr ....DISM/PKGMGR makes the "9C73FFF2-xxxxxx" folders...It's OK: I tried older versions (oldest v37) and it was the same.TNX
October 19, 201212 yr I posted somewhere else on another thread as having the same problem. Everything works except the SFX not working. I wonder what's the solution now. Thanks for any hints.
October 19, 201212 yr Author HiSorry i am late. All probs are gone. Thanks for your quick work. :giveheart:
September 21, 201312 yr Hi Silent installers issue is back to me again. Silent installers are not executed normally just before I see my first desktop but I see them being installed in the middle of Windows setup before the computer reboots for the last time. I Wonder why. Also some applications are installed successfully (such as flash player, foxit reader etc) and some are not ( like office and nero). Thanks for your help.
September 21, 201312 yr Maybe this will help:http://www.wincert.net/forum/topic/11495-wintoolkit-installer-runs-too-early/or this:http://www.wincert.net/forum/topic/10936-wintoolkit-install-apps-too-early/ Edited September 21, 201312 yr by Etz
