November 3, 201213 yr You know someting that could work lego, you could integrate the updates into the lowest sku and export it many times and then use dism to convert the next higher "target edition" (same way method used to turn Windows 8 Pro to ProfessionalWMC)Integrate the updates into Starter (for x86 iso's) or into Home Basic (for x64,) then you export it multipple times, mount each image and covert & rename themBTW off topic but you should see this new feature in Windows 8, its very, very cool you should find a way of adding this command to your toolhttp://www.msfn.org/board/topic/153742-dism-improvements-in-windows-8/page__view__findpost__p__1015509
November 3, 201213 yr That completely depends on if you decide to 'Rebuild' the image or not.okay. but doesn't Win Toolkit rebuild the image at the end of every Win Toolkit AiO integrator sessions anyhow. Please excuse my ignorance but what other methods could one use to rebuild the image?@riktendo64Sounds interesting. On the surface what your proposing sounds do-able. :g:
November 3, 201213 yr You know someting that could work lego, you could integrate the updates into the lowest sku and export it many times and then use dism to convert the next higher "target edition" (same way method used to turn Windows 8 Pro to ProfessionalWMC)Integrate the updates into Starter (for x86 iso's) or into Home Basic (for x64,) then you export it multipple times, mount each image and covert & rename themBTW off topic but you should see this new feature in Windows 8, its very, very cool you should find a way of adding this command to your toolhttp://www.msfn.org/...ost__p__1015509But wouldn't the 'upgraded' sku be missing features? For example if I did all the work on Starter and then turned it into 'Ultimate', surely some of the stuff which comes with Ultimate will be missing?Thanks for the link, however that command only works with the '/online' command and not '/image:[MountPath]'
November 3, 201213 yr Author No, every version of Windows has all the necessary the files in the winsxs folder, this is why you can integrate ALL updates into any sku, the files are waiting there for you in case you ever upgrade your edition with anytime upgradeUse /Get-TargetEditions on a mounted image and it will let you know what versions it can be upgraded to, here is starter:Editions that can be upgraded to:Target Edition : UltimateTarget Edition : ProfessionalTarget Edition : HomePremiumTarget Edition : HomeBasic
November 3, 201213 yr This would be awesome, only two images to process (X86 and X64) and all editions (except enterprise) will be added!
November 3, 201213 yr Author If you look in EVERY %WinDir%\ folder of an image you will see they all started off as being starter, because the all have a Starter.xml + <current_edition>.xml
November 4, 201213 yr Sounds promising but how would i implement it?I know that i have to mount the updated image, set edition, save, etc... But how would i implement it in WT? For example, user interface...
November 4, 201213 yr Author I would put a checkmark/warning somewhere (this will save time and detect & update the lowest and delete/replace the highest sku's,) then use imagex to detect the lowest edition in the wim, update it, see what editions it can be upgraded as, commit changes, export it as many times that are necessary (maybe also have a checkbox to what editions you want it to (re)create,) mount/change edition/commit/rename/re-flag all the imagesOr maybe put a thing in settings, where when you select the wim it will not ask you what image you want to update instead it will give you a popup warning saying that only the lowest will be updated and the highest will be recreated (also give an option what versions to rebuild)
November 4, 201213 yr Wow, sounds like quite a work load for a free tool. I had a no idea when I started this thread it would would stir up all this interest. Although it would be really cool if WT could Mirror the integrations in one edition to the next, I fear that this may cause more trouble than whats it's worth.I'm not a VB/C++ programmer, but it sounds like trying to re-invent the DISM and IMAGEX wheel in this fashion is simply not viable, but like I said, I'm not a programmer, nor I'm am familiar with all the potential of DISM and IMAGEX. In essence I dont think it's in the nature of these tools to do the things such as the ones suggested in this post. Anyways I jut wanted to add my 2 bits. I'm going to continue to follow this interesting thread for as long as it lives.Keep up the good work Liam. :prop:
January 26, 201313 yr Hey, this is really good news. I was confident you'll find a way to be able to to this. This saves a lot of time. Good work. :thumbsup:
January 26, 201313 yr Assuming that Lego finds a way to make this into a feature of Win Toolkit, then this was indeed an extremely worthwhile idea. Thanks Rick! Cheers and Regards
January 26, 201313 yr I've just used this method and it works nicely this is great, can't wait to try it in WinToolkit !
January 27, 201313 yr Awesome, thanks for your devotion in developing Win Toolkit into such a fine and respectful piece of software. Edited February 14, 201312 yr by dotfusion
January 27, 201313 yr Oh i haven't put it in WIn Toolkit (yet), i was just testing the idea out manually and it works great
January 28, 201312 yr I look forward to seeing the idea making it into a future release of Win Toolkit. Still, Many thanks for keeping Win Toolkit up2date. Oh i haven't put it in WIn Toolkit (yet), i was just testing the idea out manually and it works great
February 13, 201312 yr Any news on this ? It is the feature I'm missing the most, that would be a great time and disk/SSD saver !
December 5, 201312 yr Meanwhile, if someone ( rick, if you read me ) can post the commands used to update and export, it would be great.
December 28, 201312 yr Author If search you will find the command for turning windows 8 pro to pro with mce, just change it a bit (I do not have access to my second hdd at the moment)Mount and update your lowest SKUExport it and give it a new name/description as many times as needed. (the final export, dont need to rename it because it will stay this edition)Now you need to go mount and change the edition to all the exported/renamed images (one by one)
