Your Requests
Is it ok if i get rid of Office 2007 Updates section in W7T? It will be replaced by Office 2010 anyway
Office 2010 or Office 14 still at alpha testing stage. So its Better if u Keep the existing Office 2007 Updates Section in W7T & made a New Section for Office 2010 too. When office 2010 is released you can remove Office 2007 Update section.
I'm currently testing the Office 2010 x64 which is currently in Technical Preview stage. Technical preview is something between the beta and RC stages.
I can tell you that this tecnical preview version runs much faster than Office 2007, at least for me.
lol i don't use W7T yet
i still love working in xp
i might use him on soon on RTM
and thx for this great tool by the way
Some registry tweaks.
Can change logon Screen background.
Can enable Dreamscene.
Changing Icons.
Default Wallpaper.
Screensaver.
Themes.
Can customize right click option or context menu.
Disable UAC.
Copy to "or" move to function in right click menu.
Taking Ownership etc, etc...........
LoL you asked for it :D
Can u Add Sort Options In addon Page, like sort by size, Creator etc.
Done, all the main lists can be sorted.
Can change logon Screen background. - Will have a look
Can enable Dreamscene. - Nope, just use the addon, to do that i would have to have dreamscene.dll included with W7T
Changing Icons. - Won't do, not my area of expertise
Default Wallpaper. - Done
Screensaver. - Will have a look
Themes. - Will have a look
Disable UAC. - Already available
Copy to "or" move to function in right click menu. - Done both
Taking Ownership etc, etc........... - Done
I know it's a huge request, but it will make your Application much popular and useful.
Answer written within the qoute
How about a help manual? :D
Just ask on the forum and i'm sure someone will answer, if not i will answer :)
I want W7T in my language...
I will definitely try
ok Lego
how about adding exe setup files support
like you have one installer file but install watch would be hard so many registry
and so many copy files to include
i have a way my friend told me about in vista
it may work in 7 going to test it soon << but it should work >>
first we need to make folders like this
put the installer in the install folder
and in the scripts add the cmd file that got the installer command
the cmd must be called setupcomplete.cmd
and in it should be like
@echo off
:Programs
rem Programs are added here
start /wait %systemdrive%\install\WLMessenger9.exe
:End
rem final commands and should be ended with the cleaner command to remove
RD %systemdrive%\install /q /s
exit
Edited by DaRk MaDnEsS
ok Lego
@echo off
:Programs
:End
exit
I have my CMD Integrator and I using RunOnceEx :icon_cool: ;-)
Mount WIM, load registry, edit registry, unload registry, copy EXE,MSI,REG to %MOUNTEDWIM%\Windows\Setup or $OEM$\$1\Setup, commit %MOUNTEDWIM% and AddOn Support is here :thumbsup_anim:
REG LOAD HKLM\W7I "%MOUNTEDWIM%\Windows\System32\Config\Software"
SET ROE=HKLM\W7I\Microsoft\Windows\CurrentVersion\RunOnceEx
REG ADD %ROE% /v TITLE /d "Windows 7 Integrator Finisher" /f
REG ADD %ROE% /v Flags /t REG_DWORD /d "00000014" /f
REG ADD %ROE%\001 /ve /d "EXE" /f
REG ADD %ROE%\001 /v EXE /d "%WinDir%\Setup\EXE.exe" /f
REG ADD %ROE%\002 /ve /d "MSI" /f
REG ADD %ROE%\002 /v MSI /d "%WinDir%\Setup\MSI.exe" /f
REG ADD %ROE%\003 /ve /d "REG" /f
REG ADD %ROE%\003 /v REG /d "%WinDir%\Setup\REG.exe" /f
REG ADD HKLM\W7I\Microsoft\Windows\CurrentVersion\RunOnceEx /d "%WinDir%\System32\rundll32.exe %WinDir%\System32\iernonce.dll,RunOnceExProcess" /f
REG UNLOAD HKLM\W7I
EXE.exe
@echo Off
FOR %%i IN (C D E F G H I J K L M N O P Q R S T U V W X Y Z) DO IF EXIST %%i:\sources\install.wim SET CDROM=%%i:
FOR %%f IN ("%CDROM%\SETUP\*.exe") DO "%%f"
EXIT
MSI.exe
@echo Off
FOR %%f IN ("%CDROM%\SETUP\*.msi") DO "%%f" /passive /norestart
EXIT
REG.exe
@echo Off
FOR %%f IN ("%CDROM%\SETUP\*.reg") DO regedit /s "%%f"
EXIT
EXE,MSI,REG are compiled with QuickBFC ala ghost appz ;);-) (No CMD window)
And i have easy manage my executable AddOns in root of disk :D
Hallo an alle Windows Toolkit Nutzer,
leider ist mein englisch nicht so gut und deswegen hoffe ich, dass es in Ordnung ist, dass ich hier auf deutsch schreibe.
Nachdem wir uns bei german-winlite.de so langsam mit dem Windows 7 tools auseinandersetzen bin ich nat
Nachdem wir uns bei german-winlite.de so langsam mit dem Windows 7 tools auseinandersetzen bin ich natürlich auch auf das windows 7 toolkit gestoßen.
Ich würde mich über eine kleine Anleitung / Tutorial zum Programm sehr freuen, da es ja doch aus sehr vielen einzelnen Teilbereichen besteht.
Leider habe ich noch nicht ganz verstanden, wie ich mit dem Tool meine eigene angepasste Windows 7 DVD erstelle und wie ich damit Treiber und Addons integrieren kann. Auch das Erstellen der Addons ist mir noch nicht ganz klar.
Vielleicht wäre eine solche kurze Anleitung möglich.
Gruß beatmaster
Hallo
und bis jetzt bin ich leider sagen, dass es keine Anleitung für W7T. es wurde vor aber ich weiß nicht, ob es wird bald und bis heute kann man nur versuchen, das Programm und alle Fehler sind wir hier zu helfen.
Ich habe versucht zu helfen, aber leider bin ich nicht W7T Benutzer noch. wenn etwas nur fragen, und wir möchten helfen
i dont speak german, can someone translate please? thanks
lol neither do I ^_^
well he is requesting a guide for W7T
so i said it was already requested but i don't know if would be done
but if any question just ask and we would answer
and also saying sorry i can't talk English
REG UNLOAD HKLM\W7I
EXE.exe
@echo Off
EXIT
MSI.exe
@echo Off
EXIT
REG.exe
@echo Off
EXIT
EXE,MSI,REG are compiled with QuickBFC ala ghost appz ;) ;-) (No CMD window)
well i liked the way you handle the runonce
your commands actually works fine only if the setup files are silently with no parameters
i can use add runonce through 7zip config
but i wish to know if there is another way beside $OEM$
i gonna search for it something like true integration
Why not just create an addon which has a reg entry containing RunOnce and the setup file.
LoL that an easy one
i didn't thought of that
but here is the question where do the files go on the DVD when i integrate then using W7T
so i can make the registry :sweatingbullets:
and sometimes i don't like RunOnce i always search for something like true intergation
