Our lucky winners are:
Sebastian Schulze
Wiktoria Siewierska
Frank Mohnhaupt
Tarek Medhat Abbas
John Welter
If you are an advanced Windows user you have surely came into contact with Windows Commander or better known as Total Commander. The name had to be changed because of complaint from Microsoft.
Total commander is a powerful file manager replacement for Windows Explorer. It is fully light and ease-of-use application to view, rename, move, copy, compare, delete, search files and much more. Windows Explorer does not offer set of utilities like Total Commander and therefore this tool is essential for managing advanced file tasks.
Total Commander is shareware, but for evalution purposes it can be used for a month and after that period you should buy the license for $42. It is worth mentioning that the license model is more than fair. Once you buy the license you will get lifetime free updates with no need for license renewal.
While installation is fast and easy, advanced users may want to change the default location of INI and config files if there is a need to backup or copy customized setup of Total Commander to another PC. Total Commander features fully customizable interface. You’re able to change each icon in the toolbar, change the colors or use various available plug-ins.
Its old-school dual-pane interface gives you more power than Windows Explorer. It can use background processes for time-consuming operations so that copying larger files won’t prevent you from doing other tasks simultaneously. It also features faster file deletion and a multi-rename tool with useful options. In addition, multiple tabs can be opened in one pane, so we can have many locations/tabs opened on a PC, and thus can quickly manage files between them.
Total commander can also be used for accessing your remote file systems via built-in FTP client. The FTP client is integrated within the interface so you’re able to easily access your FTP files using keyboard shortcuts.
Total Commander can help you to compare files by content so you are able to free up some drive space by removing duplicate files from your system. It can also be used for synchronization of two directories.
User interface is not very nice as it hasn’t changed for a long time now, but this “old” design has been compensated with the speed and great usability of the application.
Total Commander supports various archive formats like ZIP, ARJ, LZH, RAR, UC2, TAR, GZ, CAB, ACE using integrated compression tool. Additionally, using already mentioned plugins Total Commander can work with any archive format.
- Two file windows side by side
- Multiple language and Unicode support
- Enhanced search function
- Compare files (now with editor) / synchronize directories
- Quick View panel with bitmap display
- ZIP, ARJ, LZH, RAR, UC2, TAR, GZ, CAB, ACE archive handling + plugins
- Built-in FTP client with FXP (server to server) and HTTP proxy support
- Parallel port link, multi-rename tool
- Tabbed interface, regular expressions, history+favorites buttons
- Thumbnails view, custom columns, enhanced search
- Compare editor, cursor in lister, separate trees, logging, enhanced overwrite dialog etc.
- Unicode names almost everywhere, long names (>259 characters), password manager for ftp and plugins, synchronize empty dirs, 64 bit context menu, quick file filter (Ctrl+S)
- USB port connection via special direct transfer cable, partial branch view (Ctrl+Shift+B), and many improvements to ftp, synchronizing and other functions
And many more!
Latest version of Total Commander can be downloade from HERE.
Giveaway info
We are offering 5 Total Commander lifetime licenses, each worth $42.
To enter this giveaway please follow us on Twitter and like our page at Facebook.
https://twitter.com/_WinCert
https://www.facebook.com/WinCert
Please leave your comment bellow with your full name so we can contact you in case you are one of our lucky winners.
Missed out on WinRAR as I found the email saying I won too late. Hope I’ll win this one as well!!
Thanks for the good giveaway
Thank you and I wish I will be a lucky winner 🙂
Thanks for the awesome giveaway.
Thanks for giveaway. please count me in
Thanks a lot for the good giveaway, I hope to win
Follow and Like done
Thanks for the great giveaway.
Thanks this is a wonderful file manager, and it does support Plugins also ability display bigger font for Total Commander at higher screen resolutions.
Awesome giveaway.
Thank you for this fabulous giveaway.
Followed on Twitter.
Great giveaway. I followed.
Thanks, very handy utility, count me in please, good luck to all
Or you could just use FreeCommander…….
Thank you for this Perfect giveaway. Total Commander is by far one of the best file managers out there.
Total commander is An incredibly powerful and intuitive software solution specially designed to make file management efficient, fast and accessible to anyone.
Thanks for the giveaway.
Liked on FB and followed on Twitter.
https://twitter.com/GrrGrrr
https://www.facebook.com/grrgrr.grr.7
O-hO-Ho!! Best contest, Best Commander – Total
https://www.facebook.com/myregkey/allactivity
I like this really GREAT, and the BEST file manager. TotalCommander is a really Multi-talent! Thanks Wincert.net for this nice contest and this chance to win a license for really GREAT and POWERFUL software from talented Programmers. TotalCommander – FOREVER! Best Regards
Thank you for the giveaway. I shared it on g+.
https://plus.google.com/107367006562718148880/posts/jQtE7NQCa3k
Thanks, excellent software and thank for the giveaway…
Thank you for the giveaway!
Thank you for the giveaway. I shared it on twitter
https://twitter.com/PolGroer/status/704759934643257344
Thank you for the great giveaway.
Thank you for the great contest.
Thank you for the great software.
Thank you for the great Total Commander 8.52a.
https://www.facebook.com/xavier.torres.7505468/posts/484541288402938
https://twitter.com/Vers67S/status/704782622648565760
Thanks for the giveaway. twitter follow_ https://twitter.com/salb4/following
liked and followed. Great giveaway of fantastic soft!
Thanks you so much for this giveaway
Thank you.
Thank you for this giveaway!
Thanks for this
Thanks for this giveaway.
Great Giveaway!
Total Commander is absolutely indispensible. Thanks . hope to win this giveaway
This is the best data manager… I followed you.
https://www.facebook.com/frank.mohnhaupt
https://twitter.com/FreakinthecageD
Thank you! I hope to win!
Great Contest. I use Total Commander.
Thanks for contest
Thanks a lot for the giveaway 🙂
Thanks For Giveaway Wincert.
Thanks
Total Commander is the all-in-one file manager replacement that offers multiple language support, search, file comparison, directory synchronization, quick view panel with bitmap display, ZIP, ARJ, LZH, RAR, UC2, TAR, GZ, CAB, ACE archive handling plus plugins, built-in FTP client with FXP, HTTP proxy support, and more.
Thanks for the contest!
One of the best giveaway.
Really so great giveaway! Thanks a lot to WinCert for hosting this awesome giveaway! I would like to try my luck on it. Hope to win 🙂 Also good luck to all participants!
All the best!
Total commander is a Ultimate powerful file manager replacement for Windows Explorer.
usually I can only use total commander trial version to see the greatness of this application and jealous of friends who could use the full version, this is a rare occasion that I was waiting to be able to re-use total commander, thank you very much for making this possible
Thanks you so much this giveaway
The most stable software I ever used !
Great app. Count me in!
Great giveaway. Count me in
Thanks for the nice giveaway.
https://twitter.com/GoWiktoriaGo
This excellent software helps me very very much, I can’t live without it
Thank you so much for developing such a superb software
Count me in, Thanks!
@Freebiessoft
Thanks alot for the nice giveaway
Thanks for the giveaway!
Count me in. Thank you!
Best file manager i know.
Thanks for offering 5 Total Commander lifetime licenses!!
