Mona UltraPacK v3.3.4 ( Fully Inf Uninstable )
This Pack Included Useful Software For Anyone.see attachment for screenshot of uninstall menus ,QTAddressBar Layout,sendto Folder(Tools,SendToA3X),open++ tools.also ImgBurn,Search Everything,Universal Extractor,Notepad++ Icon Available in Quick LaunchQTTabBar And QTAddressBar And Standard Buton Toolbar Enabled By DefaultProcessHacker Default Task Manager
screenshot.rar
Change log for version 3.3.4[added]WizTree V1.0.5[update]BlankAndSecure P-Unicode V3.67Q-Dir P-Unicode V5.51Process Hacker 2.30.0.5267SFXMaker V1.3.1 FinalCCleaner V4.0.0.4064Shutter V3.00 Beta60PicPick V3.2.3Notepad++ Unicode V6.3.1UPXEasy GUI V1.4Stickies V7.1.5.1eRufus V1.3.2.232SumatraPDF V2.3.0.7791Explorer++ V1.3.5.531Search Everything V1.3.1.636bCamStudio V2.7.r316FontViewOK P-Unicode V3.65CPU-Z V1.63SnapaShot V3.7.0.1GPU-Z V0.6.9SendToSendTo V1.2.3Notepad2 V4.2.25.837ScreenBlur V1.3.0.217zSplit & Tools V1.5 Release (build 2712)Universal Extractor V1.6.1.66eGeek Uninstaller V1.1.0.12ColorConsole P V2.05HashTab V5.1.0.23
AutoSmall V3.10
IconSize V1.0
MovieSnapshot V0.4
Seconfig XP V1.1
ShellExtensionManager V1.0.1
ShellIconFix V1.0
A.F.5 Rename your files V1.1
Quick Mailer V2.2
Easy Duplicate Finder V2.4.1
UDPixel V2.0.2615.43067
Converts units V4.10
Renamer Pro V2.0
DeskHedron 1.00
Tray ToolTipFixer V1.0.0.1
New Folder Wizard V2.1.901.0
Text To PDF V2.2
Mouse Emulator V2.2.0.0
Reg2Cmd Build 2007.12.07
SendToA3X V1.7
CMenu V2.6
Registry Jumper V2.0
PowerMenu V1.5.1.0
Kill Process V1.2.1.10
Shell Object Editor V3.11
SnapaShot V3.7.0.1
Windows Service Commander V1.0.600.2009
SendToSendTo V1.2.3
ClipX V1.0.3.9g(x86)
Magnifying Glass V1.2
HxDHexEditor V1.7.7.0
Visual Subst V1.0.6
IconSort V1.0.4
MagniGlass V1.1.0.37
Resource Hacker V3.6.0.92
RegShot V2.0.1.70
HashTab V5.1.0.23
Expander V1.5.0.0
Reg File Merger V1.0.0.0b
Reg2Inf Converter V0.4.6.0
FGCBA V0.8.9.7
Replacer V2.63
UniversalThemePatcher V1.5.0.22
Show Desktop V1.211
CamStudio V2.7.r316
FFSJ V3.3.0.0
HotFix Extractor V1.0.0.1
Microsoft Calculator Plus v1.0 (Replaces calc.exe)
CAB Tool V1.8.0.0
TSkill 5.1.2600.0
ModifyPE V0.8
MS TrueType Font Properties V2.3.0.0
SelectAll V3.0.0.0
FileExtToggle V3.0.0.0
HiddenFilesToggle V3.0.0.0
BrowserBack V3.0.0.0
Mainsoft ClipName v1.3.0
Microsoft Makecab v6.0.6001.22192 (Vista SP2 final version)
HighMAT CD Writing Wizard V1.1.1905.1
RegTweaks Toolbar...
For Toolbar,HideGoButton,HideMenubar,Throbber,CustomToolbar,LockToolbar
Open In A New Window(Called New Window) RegTweak
Advanced Install,Uninstall RegTweak
Copy ; Move To... RegTweak
RecycleBin In Start Menu RegTweak
Quick Launch RegTweak Enabled By Default
ClearType Enabled By Default
TrueTransparency 1.4.1.189
HashCheck Shell Extension V2.1.11.1
PicPick V3.2.3
ImgBurn V2.5.7
VisualToolTip V2.2.1
InstallWatch Pro 2.5c
QTAdressBar V0.9.6
RocketDock V1.3.5
WinFlip V0.50
Universal Extractor V1.6.1.66e Based on gora-sah addon
ISO Toolkit 5.0
ColorConsole V2.05
FontViewOK V3.65
MediaTab V1.1.9.0
Winstep Start Menu Organizer V1.5.0.89
T-Clock 2010 V2.0.1.95
Notepad2 V4.2.25.837 And MetaPatch 4.0.13
Notpad2 mod link
Reg2exe V2.30.2010.519
Unlocker v1.9.1
NirCmd V2.6.5.215
VistaSwitcher V1.1.5
SumatraPDF V2.3.0.7791 - Pre Release
Open++ V1.5.1.0
(Open Command Prompt,Copy Path,Change Properties,Create Sub Folder,View File
Checksum,Run With Arguments,Register DLL,Unregister DLL,
Copy Shortcut Target,Find Shortcut Target,Notepad,Paint)
AquaSnap V1.6.3
Image Uploader V1.2.7 Build 4176(27.03.2012)
WalykWallpaperChanger V1.6.0.2
Secure Folder V5.7
QTTabBar V1.5.0.0 Beta 2
Styler V1.4.0.1
Process Hacker V2.30.0.5267
Runscanner V2.0.0.60
ActiveHotkeys V1.1.0.8
EasyBCD V2.2.0.182
7.1.5.1e
SageThumbs32-bit 2.0.0.15
Empty Folder Nuker 1.3.0
BootSafe V2.0.0.1000
Rufus V1.3.2.232
BlueScreenView V1.4.5
WhatInStartup V1.33
WinUpdatesList v1.31
MemoryTest V1.0.0.1
UPXEasy GUI V1.4
HWMonitor V1.2.0
CPU-Z V1.63
GPU-Z V0.6.9
Smart Driver Backup V2.12
HPUSBFormatTool V2.1.8
ClearType Control Panel V1.0.0.3
ScreenBlur V1.3.0.21 XP
Microsoft Time Zone V2.1.30.0
WizTree V1.0.5
Must Special Thanks To ricktendo64,Geej, Kelsenellenelvian For Kels UberPacK ,MMM+;dougiefresh and mooms for QT AddressBar, ENU_user For ImageFileConverter
also i can not allways on so dont can allways update it,its open for anyone to updated it.
you may get Mona_Ultra_Addon_v3.xx.7z contains a virus,this is a for Reg2exe.exe this is False positive
Since New Version Of Secure Folder And EasyDuplicateFinder Need Registerion Key
I Dont Update And Keep Current Version
Download
Mona_Ultra_Addon_v3.3.4
File  : Mona_Ultra_Addon_v3.3.4.7zSize  : 73.0 MBCRC-32: B10E6691MD5   : CF1C4A9A231179608D1BA5BF565BE5D3SHA-1 : F3CAB21EFACD0826F0EB2DA23E255F731D6FA2D2
frist login to hotmailgo to link and to this folder "Mona_Ultra_Addon"then click on the file namenow in right side ofwindow(or icon of helpin the filename, thissow information of file)see "Download" text click onit to download .
[Attanion To Uninstall]The underside tool need at least one logoff to completeUninstall.also some tool like (Open++,ImageUploader) whenhave version update must Uninstall and logoff then installupdate.or if you Uninstalled one of the underside toolmust logoff then install update.PowerMenuOpen++UDPixelUnlockerHashTabMS TrueType File PropertiesSelectAllFileExtToggleExtensionHiddenFilesToggleExtensionClipNameBrowserBackHighMAT CD Writing WizardFileSpliterMediaTabCMenuHashCheckWinFlipQTAddressBarImageUploader
Edited by mona
  • Replies 59
  • Views 36k
hmmm
these are dark times indeed!first kal's sweet candybar pack, then mona's uberpack..
Don't blame me but i think around here the word "uberpack" is connected with kel's pack. Even though this pack is different it may confuse people, so you could choose another name, e.g. Ultrapack, catchy?
BTW it is a really good add on.
Well Done!
do you can anyone help for correct inf file i before post addon test and worked but when install new winxp
when install get error i see inf file but not see error in the inf file tested with fgcba .
Off-Topic Comment(Click to Show)
IMHO Kel coined the term "Uber"Pack I think you should name your something other than Uber
[Close]
ichanged but get error see MulyMona.rar
[Close]
""error install inf,parametr not correct"" :(--uninstall tool is crasched
grzegorzo add Polish.xmlPolish.rar lang folder in a
\Utility\Uninstall Tool\lang
Hi Mona,
Thank you for this pack! you put some kick-ass bits in there...
I am having problems with it, though... the INF install error, for one, and the fact that no shortcuts are created to get to the programs...
Keep up the good work!
Hi Mona,
Hi Mona,
Any chance to get this nice addon fixed? BUMPITY-BUMP! :-)
addon not updated but i think find bug in addon when remove this(line:272,273,274)in [Cln.addreg] section addon worked. i finded error in setupapi.log from windows directory
#E008 Setting registry value HKU\S-1-5-21-1004336348-1767777339-725345543-1003\Software\VB And VBA Program Settings\CCleaner
#E033 Error 87: The parameter is incorrect.
HKU,"S-1-5-21-1004336348-1767777339-725345543-1003\Software\VB And VBA Program Settings\CCleaner",,0
HKU,"S-1-5-21-1004336348-1767777339-725345543-1003\Software\VB And VBA Program Settings\CCleane\Options",,0
HKU,"S-1-5-21-1004336348-1767777339-725345543-1003\Software\VB And VBA Program Settings\CCleaner\Options","Language",0,"1033"
and must wait for add other sofware and(fix problem)to addon pack
Edited by mona
Updated!
  • 10 months later...
  • 2 years later...
Updated
Could you please double check the file. For some reason I can't seem to download this file. Thanks in advance.
hi
whats your problem?
in firefox frist login to hotmail
go to link and to this folder "Mona_Ultra_Addon" then click on the file name
now in right side of window(or icon of help in the filename, this sow information of file) see "Download" text click on it to download .
Thanks. Logging into hotmail first was apparently the trick. I haven't had to do that to download from skydrive before, but it's been awhile since I've used it so maybe something has changed? Anyway, your instructions work for both firefox and Chrome (Iron), so it might be helpful to add them to the first post to help others?
updated
You're welcome
updated
updated
