[AddOn] Windows Vista RTM Sidebar (XP Only)
  • Replies 189
  • Views 460k
Changelog:
July-11-07
- Twead INF uninstall
- Quick Lauch shortcut is back
- Fixed Vista Calculator Gadget
June-22-07 Sidebar v7.06.22
- Added VAIO XP and Vista Fonts to the Sidebar Addon and made a AIO
- Updated my VistaLHClocks Gadget mod
May-25-07 Sidebar v7.05.25
- Removed Slideshow Fix (Dont get me started on why)
- Added Control Panel Shortcut for Sidebar Propeties (Thanks to SoKoOLz)
May-19-07 Sidebar v7.05.19
- Added Slideshow Fix to Sidebar Directory (vshell32.dll)
- Updated Live Clock and other gadgets (removed a couple)
- Tweaked INF
Apr-8-2007 Sidebar v2.4
- Improved INF Uninstall script
- Updated iClock and Live Clock
- Added Negative CPU, BBC Radio and JoeJoe.org Gadgets
- New Seperate ATL.DLL AddOn that makes Sidebar Compatible with both XP and 2k3
- Added hacked wlsrvc.dll to fix problem with the Weather gadget not working for some
ReadMe FAQ:
Q: I dont use nLite, how do I install the Sidebar AddOn manually?
- Install VAIO and all its Required Programs (IE7, WMP11, WLAN-API)
- Download the Installer http://www.wincert.net/forum/index.php?showtopic=505
Q: How do I install the Gadget I just downloaded?
- Use a free program archiver such as 7zip
- Right Click on the Example.Gadget, select 7zip -> Extract files... and hit OK (It will extract your Gadget to a sub folder)
- Copy extracted Example folder to "%ProgramFiles%\Windows Sidebar\Shared Gadgets" and ADD .Gadgets to the extracted gadget folder's filename
- If you use WinRAR or WinZip change the file extention from .Gadget to .zip or .cab and extract it that way.
Note: .Gadget files are nothing but renamed .cab or .zip files
Q: I get the following ERROR
Sorry. This application attempted to delay-load a library or function that does not exist. Instability may occur.
- WLAN-API is not installed
Q: I get a vADVAPI32.dll ERROR
This application has failed to start because vADVAPI32.dll was not found. Re-installing the application may fix this problem.
- VAIO was not installed/integrated
Q: Some Gadgets are blurry and don't have any trasparency
- Internet Explorer 7 might not installed/integrated
Q: The Gadgets don't work; the Clock Gadget is black, only shows the glass and the second hand
- Go to Add Remove Programs and hit the Change button to re-register the files and Restart the Sidebar
- OR try running this CMD file RegSidebar.rar
Q: The Slideshow Gadget's Picture is Zoomed In @ 100%
- Known VAIO bug that will be fixed in b3
Very Special Thanks:
SoKoOLz
ears1991 (sidebar skins)
Rafael & ZoRoNaX for creating VAIO (the best thint to happen to XP)
First off I just wanted to also say thanks Ricktendo64 And Everyone Else That Contributed!!! Sidebar Works great!!!
Update 7/14/07: NEW VERSION!! Built using .NET 2.0 which is required and can be downloaded below:
Now is anyone interested in a way to auto extract the downloaded gadget files?? I recommend using Version 3 if you have or can install .NET 2.0
The new version 3 does not use a batch file and was built using .Net 2.0. If you want the batch file option or the exe wrapped batch file so that the batch window is not seen during extraction (Gadget Extractor Version 2), I have left the ones I created below in the download section. All versions only work with XP and expect the sidebar be installed in the below folder which is the default install folder. If it is not, download the manual install and edit the batch and registry files accordingly. Version 2 and above should no longer require 7zip be installed
Required Sidebar Install Path: "%ProgramFiles%\Windows Sidebar\"
I give no guarantees that these will work but please let me know if they do or don't work and I'll do my best to fix them if posssible.
Those that can, feel free to modify or fix the batch file for any reason or to improve it. Anyone that wants the souce code just PM me.
If it works now or after modification maybe it can be included with the sidebar install package.
All files were scanned for viruses just before upload using AVG Free with most recent database.
Fmustang76
-------------------------------------DOWNLOAD SECTION----------------------------------
NEW VERSION
If you want to try version 3, it is packaged into a standard windows installer. This one requires .NET 2.0 be installed.
Gadget Extractor Version 3 Package
.NET 2.0 Redistibution Package 22.4MB
How to extract gadgets after Gadget Extractor Version 3 is installed:
1. Download gadget and save to hard drive.
2. Double click gadget file to extract
or
3. Open gadget extractor and select gadget file to extract.
If the gadgets file type association becomes corrupted, just run Gadget Extractor to auto fix the file type associations(version 3 Only).
OLD VERSIONS
If you want to try Version 2, it is packaged into a standard windows installer and installs everything needed.
Gadget Extractor Version 2 Package
If you want to use the batch file itself or manually install download the file below.
Manual Install Gadget Extractor Package
Edited by Fmustang76
Since there is a problem with with what seems to be the wireless api for XP, and several of us want or try to use the wireless network gadgets, I have removed the problem code from the original gadgets so they will work with the Vista RTM Sidebar as a tempoary fix. I have left everything else as it was but because of the this problem, they do have limited functionality, as they will not display the wireless SSID or network address, which was causing the delay-load errors for those gadgets. Otherwise, as designed, they do work as signal strength meters displaying whether there is a connection, how strong a connection, and is it a secure connection or not, with the options depending on the gadget.
Go to the download website and select the gadget to download.
Network Gadget Download Website
I have only tested these on my laptop so I give no guarantee they will work but please let this forum know if they work for you or not.
Thanks
Fmustang76
  • 4 weeks later...
Cleaned up Topic
Updated Sidebar AddOn:
Hi
Firstly i gotta say that this sidebar is the best thing to ever happen to xp/server 2003, because you can use the gadgets from www.gallery.live.com unlike thoosjes sidebar which cant support user made gadgets.
Now because i had a hard time getting this sidebar to work properly not mentioning the gadgets to work on the sidebar,ive put together a package that includes all the install files needed to install the sidebar on xp, including how to add gadgets and skins, sooo this package is for those very confused users.
If i may rick could i upload the file or not please tell me if you dont want me to
XZ0r
:questionmark:
Hi
XZ0r
:questionmark:
Yes, you can upload it, and after Rick checks it, he will decide whether that topic will be pinned or not..
Cheers and thx
Dude, this sidebar port is the next best thing since the idea of porting console games (EMU) to PC :D ... o.k. maybe a bit over exaggerated.. BUT the API alone is worth a coder's award. Who knows maybe someone will find a way to have xp/vista run with Linux's XGL.. ha ha wouldn't that be a blast. Keep up the good work.
Edited by HardDisk
hey rick,
you think you can remake the install's or whatever needs to be changed to get this to work on XP x64.... I have gotten everything else to install but I cannot seem to get your sidebar to install (doing this manually i didn't want to integrate it...)
THX if you can
The install probably fails because I did not include regsvr32.exe in with the sidebar files... This is for 2k3 compatibility, the regsvr32.exe from XP will not work on 2k3 and vice versa
-Install VAIOXP (SideNote: The VAIO Shell Extention will not show up in XP x64 but there is a trick on how to get this to show... But I forgot how, something about loading a seperate explorere.exe thats located in a seperate folder)
- So when installing this manually copy regsvr32.exe from system32 and place it in the same directory as Sidebar.cab and Sidebar.inf
- Right Click on Sidebar.inf and select install (error pops up)
- Browse to Sidebar.cab and hit Select then OK
- Finally copy Sidebar.inf to X:\WINDOWS\inf (make sure to turn on "Show Hidden Files")
- Go to Add/Remove Programs in the Sidebar uninstall section hit the Change button (this will register the sidebar DLL and EXE files)
- Start the sidebar
from what I can tell.... nothing pops up.... it registers an entry in teh Add/Remove.... however it goes no further.... kinda like app kill but unintended.... this sucks..... x64 works great with 8GB but no sidebar is killing me (and Vista SUCKS)
Hi!
I built an integrated WinXP installation disc using nLite 1.3 final. No errors during integration or installation. Anyway Windows Sidebar fails to start and I'm suggested to send an error report to M$. It's about a System.io.filenotfoundexcpetion of .NET FW 2.0: I can read this in the Event Viewer.
Uhm.. :(
Mic
P.S.: I'm running WinXP on a virtual machine created with VirtualBox (VMWare clone): prior to formatting my drive I want to be sure the "nLited XP" works fine.
Edited by MicHardw
@ Kane
Sorry I'm fresh out of ideas
@ CBC888
No you don't need it cuz its included in the VAIO MSI Installer
@ MicHardw
- Did you integrate the VAIO addon?
- Do you use the RyanVM Updatepack and if you DIDN'T use it did you integrate the alternate WLan - API hotfix AddOn thats above?
- Did you use the latest nLite?
- How about IE7 and WMP11 addons. Did you integrate them also?
- What does your error say?
Here are some things to try:
Install VAIO if you havent integrated it
Install this WLan Hotfix and let me know if any of this helped
Hi Ricks! Using your new 2k3 Vista Sidebar Addon (v2.4) i've encountered a problem that i've already solved now but maybe explaining it i can help someone...
So, everytime i tried to run the sidebar i got the "famous" delay-load error, that on windows xp is caused by wlan but is very strange on win 2k3... After some experiments i noticed that some files in your Sidebar.cab have a different date (different day) from those in ^SoKoOLz^'s installer... Then i've replaced your files with those from the installer, i've repacked your addon, i've tried it and everything works! No more delay-load error but only a perfect sidebar!
These are the files that i've replaced:
sbdrop.dll
sidebar.exe
wlsrvc.dll
wlsrvc.dll.manifest
Byezzzzz :welcome:
@ Carillo Gallardo
Thanks for the bug report
@ CBC888
Both are the exact same installer (extract the exe and you will see its the same msi installer, just that i make it silent using 7zip)
@ CBC888
Thanks, that's good to know.
There still seems to be much confusion about the Visual C++ 2005 Redistributable Package, however, since most websites still indicate that this needs to be installed - even with the latest version of VAIOXP (which includes "the merge modules for the Visual C++ redistributable modules").
hi rick can you help when i open some gadgets i get error like this. i got XP and VAIO and get a error " a runtime error has occurred. do you wish to debug? Line: 180 Error: 'settingsclosed' is undfined"
pls help thx
Thanks
Fmustang76
thanks! I like the istat wireless gadget.. but it shows 2 ip address maybe it's better to show only 1 ip address and the other one is the name of the network you are connected to
Hey rick.. is there any temperture monitoring gadget for this styler so you cold monitor CPU, GPU ,etc temps?
And onem ore Q about Windows Sidebar Styler...is there any folder root about it? I added all those things mentioned on first page including .net 3.0 but I cant' find Styler options? Am I missing something?
Added (Ricks_VAIOXP-b2r3.4_AddOn_v1.1, Ricks_VistaRTMFonts_AddOn_v1.1, Ricks_VistaRTMSidebar_AddOn_v2.4, Ricks_WindowsSidebarStyler2.0.5_AddOn)
@ Gorky
You have to make sure that you put Windows Sidebar Styler AFTER dotNet 2 or 3 in the SVCPACK Install Order, the installer will fail if it does not detect at least dotNet 2 installed
Bout the temp gadget, I think there is one for fanspeed and everest ultimate is said to have one (but it only works if everest is running)
EDIT: Yep it has a Gadget and it works on the XP sidebar also (im uploading the Everest AddOn now)
@ Gorky
Hmm..that is little bit tuff to do...cause I used RogueSpearAddonsDotNET30 addon and I cant' see that addon on rogue runtime list page? :( And net.3 is requred. Do you think that changing the install order in Nlite could do the trick? :unsure:
