[Tool] DX's Universal UpdatePack/Addon Creator
DXUPAC
tabdownload.png Update (2016)
Video tutorial: how to create your localized Onepiece's UpdatePack (and IE, WMP11 or Silverlight Addons) with DXUPAC
This tool allows you to create a localized UpdatePack or Addon, simply following these steps:
Place in a folder (source folder) the complete source already updated with the latest Service Pack and exactly all the hotfix installers and additional components listed in Onepiece's AIO UpdatePack topics (for XP and 2003 UpdatePacks) or the setup file and all the eventually needed hotfix installers (for Addons). UpdatePack INTL Files or UpdatePack INTL Files you can find the needed hotfixes updated lists for the 24 main XP localizations..
If you are creating UpdatePacks, you need add in source folder the following addons:
netfx 3.5 gdr addon
netfx 4.0 gdr addon
Starting from June release you must also add this addon in source folder
in place of install_flash_player_ax.exe file, because Flash installer doesn't support anymore 7-Zip.
Run DXUPAC.exe with the needed settings and the path of source folder.
When finished, you get your own localized addon/pack in 7z format, WU-compliant. The only thing missing will be your localized .net 3.5/4 language packs . You can add them too using Svcpack addons you can build with another easy tool available here . You need only to place in same directory dotnetfx35langpack_x86**.exe and dotNetFx40LP_Full_x86**.exe files you'll get from Microsoft and run.
Only for Unicode language XP users (like ARA, CHS, CHT, ELL, HEB, JPN, KOR, RUS): you should update manually the TimeZone Hotfix lines as DXUPAC is not able to to take out lines in local language so they are created in English. You need to extract latest TimeZone KB (you find them under [TZ_KBLAST.AddReg]) and update all lines from Argentina_Display=* to Yakutsk_Display in Strings section.
Trust me: creating an Onepiece's localized AIO UpdatePack need only a few clicks. So please don't ask for ready-to-use UpdatePacks, you can do it by yourself, we really got no time to rebuild 24 different updatepacks every month. Thank you for your comprehension.
Universal Creator can also integrate Service Pack 3 inside XP MCE 2005. Follow these steps (some screen are from italian XP but they are easily comprehensible):
Or
After slipstreaming of Service Pack 3 in MCE sources, integration of Onepiece's XP postSP3 AIO UpdatePack is strongly suggested.
When done, you can also add the XPMediaCenter specific hotfixes (by integrating them at T-13: here you can find a step-by-step guide, in italian but with screenshots)
Thanks to Yumeyao for his suggestions.
Please be tolerant if something is not enough clearly stated. It's more easier to run than explain how it works
Edited by nonno fabio
  • Replies 301
  • Views 237k
  • Did you use the latest tool (dated August 15th) for that??? With the previous build before this it didn't work as I explained in my post. I'll build the addon with this latest tool and get back to you
  • Hi zzzzzz, perhaps better to look here http://www.ryanvm.net/forum/viewforum.php?f=9 about Pack\AddOn x64 Ciao.
  • nonno fabio
    nonno fabio
    updated to fit latest XP/w2k3 UpdatePacks
Here are the supported programs/OS
newest Windows XP AIO Update Pack INTL
You must use a Win XP SP3 clean source and the hotfixes and additional components listed in Onepiece's XP postSP3 UpdatePack topic.
newest Windows Server 2003 AIO Update Pack INTL
http://www.ryanvm.net/forum/viewtopic.php?t=5591&start=0
You must use a Win 2003 SP2 clean source and the hotfixes and additional components listed in Onepiece's w2k3 postSP2 UpdatePack topic.
Internet Explorer 7-8 True or SvcPack or RunOnceEx AddOn INTL
Windows Media Player 11 True AddOn INTL
DirectX True AddOn INTL
Silverlight True or SvcPack or RunOnceEx AddOn INTL
CCleaner - INTL True Mode (Windows XP & Windows Server 2003 only)
You must rename ccsetup*.exe file in ccsetup.exe or in CCleaner_Setup.exe
Sun xVM VirtualBox x86&x64 - INTL Svcpack Mode
You must rename VirtualBox*.exe file in VirtualBox.exe or in VirtualBox_Setup.exe, then run Creator and input the directory where VirtualBox.exe or VirtualBox_Setup.exe is stored.
Windows Defender - INTL RunOnceEX Mode
Run Creator and input the directory where WindowsDefender.msi is stored: Creator uses wget.exe so if you're online it verifies if the definitions file (mpas-fe.exe) you've placed inside source folder along with WindowsDefender.msi is the latest one. If not, it will download the new one before starting to build the addon.
Adobe Reader - INTL Svcpack Mode
You must rename AdbeRdr*.exe file in AdbeRdr.exe or in AdbeRdr_Setup.exe, then run Creator and input the directory where AdbeRdr.exe or AdbeRdr_Setup.exe is stored: Creator uses wget.exe so if you're online it verifies if Reader Updates (AdbeRdrUpd912_all_incr.msp, AdbeRdrUpd913_all_incr.msp, etc. ) you've placed inside source folder along with WindowsDefender.msi are the latest one. If not, it will download the new one before starting to build the addon.
Foxit Reader - ITA & ENU Svcpack Mode
.net 1.1 true addon localization
needs Onepiece's .net. 1.1 en-us true addon and .net 1.1 language pack in your language
Vista boot screen
You need to extract updated Windows XP kernel files (ntkrnlmp.exe ntkrnlpa.exe ntkrpamp.exe ntoskrnl.exe) from the latest available hotfix (today 2010-02-19 is KB977165)
and more...
Here's an example of a localized updatepack automatically created with AIO Creator:
OnePiece Windows XP Post-SP3 UpdatePack v2.8.1_CSY
tabdownload.png Updated (March 04-2009)
Hash MD5 6DEE3567D14835ACE5E322EBCB55B703
Filesize: 109 MB (114492547 bytes)
hotfixes and settings needed:
DXUPACFG.ini
[DXUPACFG]
LANGUAGE=Czech
directx_aug2009_redist.exe
EUupdate.EXE
IE8-WindowsXP-KB971961-x86-CSY.exe
IE8-WindowsXP-KB972260-x86-CSY.exe
IE8-WindowsXP-KB973874-x86-CSY.exe
IE8-WindowsXP-x86-CSY.exe
IMAPI_XP_SRV2003_x86 CSY.exe
KB952011 SmartCard_XP_x86 CSY.exe
KB961184-CS-CZ.exe
LegitCheckControl.cab
msxml.msi
msxml2sp6-kb887606-x86-csy.exe
MuCatalogWebControl.cab http://catalog.updat...b?1197661333312
mucltui.cab http://download.wind...her/mucltui.cab
mucltui_cs.cab http://download.wind.../mucltui_sv.cab
muweb.cab http://download.wind...Other/muweb.cab
rootsupd.exe KB931125: must have this name
rvkroots.exe KB2728973: must have this name
Silverlight.exe
Windows-cs-CZ-KB974266.exe
windows-kb890830-v2.14.exe
Windows-KB909520-v1.000-x86-CSY.exe
windowsmedia11-kb928788-x86-intl.exe
windowsmedia11-kb929399-v2-x86-intl.exe
windowsmedia11-kb929773-x86-intl.exe
windowsmedia11-kb932390-x86-intl.exe
windowsmedia11-kb933547-x86-intl.exe
windowsmedia11-kb935551-x86-intl.exe
windowsmedia11-kb935552-x86-intl.exe
windowsmedia11-kb939209-x86-intl.exe
WindowsMedia11-KB939683-x86-CSY.exe
windowsmedia11-kb944882-x86-intl.exe
windowsmedia11-kb954069-x86-intl.exe
WindowsMedia11-KB954154-x86-CSY.exe
windowsmedia11-kb973442-x86-intl.exe
WindowsRightsManagementServicesSP2-KB917275-Client-CSY.exe
WindowsSearch-KB940157-XP-x86-csy.exe
WindowsServer2003.WindowsXP-KB963093-x86-CSY.exe
windowsupdateagent30-x86.exe
WindowsXP-KB817688-x86-CSY.exe
WindowsXP-KB889320-v2-x86-CSY.exe
WindowsXP-KB897571-x86-CSY.exe
WindowsXP-KB898461-x86-CSY.exe
windowsxp-kb905474-csy-x86.exe
WindowsXP-KB915800-v4-x86-CSY.exe
WindowsXP-KB916157-v6-x86-CSY.exe
WindowsXP-KB922120-v6-x86-CSY.exe
WindowsXP-KB923561-x86-CSY.exe
WindowsXP-KB926139-v2-x86-CSY.exe English only, you must rename ENU in CSY
WindowsXP-KB927436-v2-x86-CSY.exe
WindowsXP-KB932716-v2-x86-CSY.exe
WindowsXP-KB934401-x86-CSY.exe
WindowsXP-KB938759-x86-CSY.exe
WindowsXP-KB940159-v2-x86-CSY.exe
WindowsXP-KB940648-x86-CSY.exe
WindowsXP-KB941569-x86-CSY.exe
WindowsXP-KB942288-v3-x86.exe
WindowsXP-KB943232-v2-x86-CSY.exe
WindowsXP-KB944043-v3-x86-CSY.exe
WindowsXP-KB945060-v3-x86-CSY.exe
WindowsXP-KB945184-x86-CSY.exe
WindowsXP-KB945436-x86-CSY.exe
WindowsXP-KB946648-x86-CSY.exe
WindowsXP-KB947460-v3-x86-CSY.exe
WindowsXP-KB948101-v3-x86-CSY.exe
WindowsXP-KB948277-x86-CSY.exe
WindowsXP-KB948720-x86-CSY.exe
WindowsXP-KB948877-v2-x86-CSY.exe
WindowsXP-KB949127-v2-x86-CSY.exe
WindowsXP-KB949900-x86-CSY.exe
WindowsXP-KB950305-v2-x86-CSY.exe
WindowsXP-KB950312-x86-CSY.exe
WindowsXP-KB950616-x86-CSY.exe
WindowsXP-KB950820-x86-CSY.exe
WindowsXP-KB950974-x86-CSY.exe
WindowsXP-KB950982-x86-CSY.exe
WindowsXP-KB951066-x86-CSY.exe
WindowsXP-KB951159-x86-CSY.exe
WindowsXP-KB951163-x86-CSY.exe
WindowsXP-KB951347-x86-CSY.exe
WindowsXP-KB951376-v2-x86-CSY.exe
WindowsXP-KB951531-v2-x86-CSY.exe
WindowsXP-KB951618-v2-x86-CSY.exe
WindowsXP-KB951624-x86-CSY.exe
WindowsXP-KB951709-x86-CSY.exe
WindowsXP-KB951822-v2-x86-CSY.exe
WindowsXP-KB951978-x86-CSY.exe
WindowsXP-KB952004-x86-CSY.exe
WindowsXP-KB952117-v2-x86-CSY.exe
WindowsXP-KB952595-v3-x86-CSY.exe
WindowsXP-KB952909-v2-x86-CSY.exe
WindowsXP-KB952954-x86-CSY.exe
WindowsXP-KB953024-x86-CSY.exe
WindowsXP-KB953028-x86-CSY.exe
WindowsXP-KB953155-x86-CSY.exe
WindowsXP-KB953761-x86-CSY.exe
WindowsXP-KB953930-x86-CSY.exe
WindowsXP-KB954193-x86-CSY.exe
WindowsXP-KB954232-x86-CSY.exe
WindowsXP-KB954434-x86-CSY.exe
WindowsXP-KB954600-x86-CSY.exe
WindowsXP-KB954708-x86-CSY.exe
WindowsXP-KB954920-v2-x86-CSY.exe
WindowsXP-KB955043-v2-x86-CSY.exe
WindowsXP-KB955069-x86-CSY.exe
WindowsXP-KB955109-x86-CSY.exe
WindowsXP-KB955356-x86-CSY.exe
WindowsXP-KB955417-x86-CSY.exe
WindowsXP-KB955567-x86-CSY.exe
WindowsXP-KB955576-x86-CSY.exe
WindowsXP-KB955704-x86-CSY.exe
WindowsXP-KB955830-v2-x86-CSY.exe
WindowsXP-KB955843-v4-x86--x86-CSY.exe
WindowsXP-KB955843-v4-x86-CSY.exe
WindowsXP-KB955988-x86-CSY.exe
WindowsXP-KB956048-x86-CSY.exe
WindowsXP-KB956072-x86-CSY.exe
WindowsXP-KB956572-x86-CSY.exe
WindowsXP-KB956625-x86-CSY.exe
WindowsXP-KB956844-x86-CSY.exe
WindowsXP-KB957218-x86-CSY.exe
WindowsXP-KB957264-x86-CSY.exe
WindowsXP-KB957495-x86-CSY.exe
WindowsXP-KB957502-x86-CSY.exe
WindowsXP-KB957579-x86-CSY.exe
WindowsXP-KB957931-x86-CSY.exe
WindowsXP-KB958071-x86-CSY.exe
WindowsXP-KB958149-x86-CSY.exe
WindowsXP-KB958244-x86-CSY.exe
WindowsXP-KB958259-v2-x86-CSY.exe
WindowsXP-KB958644-x86-CSY.exe
WindowsXP-KB958687-x86-CSY.exe
WindowsXP-KB958817-x86-CSY.exe
WindowsXP-KB958910-x86-CSY.exe
WindowsXP-KB958911-x86-CSY.exe
WindowsXP-KB959085-x86-CSY.exe
WindowsXP-KB959160-x86-CSY.exe
WindowsXP-KB959267-x86-CSY.exe
WindowsXP-KB959334-x86-CSY.exe
WindowsXP-KB959426-x86-CSY.exe
WindowsXP-KB959465-x86-CSY.exe
WindowsXP-KB959540-x86-CSY.exe
WindowsXP-KB959554-x86-CSY.exe
WindowsXP-KB959682-x86-CSY.exe
WindowsXP-KB959765-x86-CSY.exe
WindowsXP-KB959873-x86-CSY.exe
WindowsXP-KB960064-x86-CSY.exe
WindowsXP-KB960071-v2-x86-CSY.exe
WindowsXP-KB960519-x86-CSY.exe
WindowsXP-KB960655-x86-CSY.exe
WindowsXP-KB960680-v2-x86-CSY.exe
WindowsXP-KB960803-x86-CSY.exe
WindowsXP-KB960859-x86-CSY.exe
WindowsXP-KB960921-x86-CSY.exe
WindowsXP-KB960970-x86-CSY.exe
WindowsXP-KB961067-x86-CSY.exe
WindowsXP-KB961118-x86-CSY.exe
WindowsXP-KB961187-v2-x86-CSY.exe
WindowsXP-KB961371-v2-x86-CSY.exe
WindowsXP-KB961451-v2-x86-CSY.exe
WindowsXP-KB961503-x86-CSY.exe
WindowsXP-KB961555-x86-CSY.exe
WindowsXP-KB961605-x86-CSY.exe
WindowsXP-KB961853-v2-x86-CSY.exe
WindowsXP-KB963038-x86-CSY.exe
WindowsXP-KB965220-x86-CSY.exe
WindowsXP-KB967048-v2-x86-CSY.exe
WindowsXP-KB967705-v2-x86-CSY.exe
WindowsXP-KB967756-x86-CSY.exe
WindowsXP-KB968389-x86-CSY.exe
WindowsXP-KB968585-v2-x86-CSY.exe
WindowsXP-KB968730-x86-CSY.exe
WindowsXP-KB968764-x86-CSY.exe
WindowsXP-KB969111-x86-CSY.exe
WindowsXP-KB969238-x86-CSY.exe
WindowsXP-KB969262-x86-CSY.exe
windowsxp-kb969395-x86-csy.exe
WindowsXP-KB969557-x86-CSY.exe
WindowsXP-KB969632-x86-CSY.exe
WindowsXP-KB970048-x86-CSY.exe
WindowsXP-KB970063-x86-CSY.exe
WindowsXP-KB970238-x86-CSY.exe
WindowsXP-KB970254-x86-CSY.exe
WindowsXP-KB970326-x86-CSY.exe
WindowsXP-KB970413-x86-CSY.exe
WindowsXP-KB970483-x86-CSY.exe
WindowsXP-KB970553-x86-CSY.exe
WindowsXP-KB970653-v3-x86-CSY.exe
WindowsXP-KB970685-x86-CSY.exe
WindowsXP-KB970922-x86-CSY.exe
WindowsXP-KB971029-x86-CSY.exe
WindowsXP-KB971165-x86-CSY.exe
WindowsXP-KB971234-v2-x86-CSY.exe
WindowsXP-KB971250-x86-CSY.exe
WindowsXP-KB971276-v3-x86-CSY.exe English only, you must rename ENU in CSY
WindowsXP-KB971314-x86-CSY.exe
WindowsXP-KB971323-x86-CSY.exe
WindowsXP-KB971345-x86-CSY.exe
WindowsXP-KB971421-x86-CSY.exe
WindowsXP-KB971455-x86-CSY.exe
WindowsXP-KB971557-x86-CSY.exe
WindowsXP-KB971633-x86-CSY.exe
WindowsXP-KB971657-x86-CSY.exe
WindowsXP-KB972435-x86-CSY.exe
WindowsXP-KB972828-x86-CSY.exe
WindowsXP-KB972878-x86-CSY.exe
WindowsXP-KB973093-x86-CSY.exe
WindowsXP-KB973296-x86-CSY.exe
WindowsXP-KB973346-x86-CSY.exe
WindowsXP-KB973354-x86-CSY.exe
WindowsXP-KB973502-x86-CSY.exe
WindowsXP-KB973507-x86-CSY.exe
WindowsXP-KB973624-x86-CSY.exe
WindowsXP-KB973815-x86-CSY.exe
WindowsXP-KB973869-x86-CSY.exe
WindowsXP-WindowsMedia-KB952069-v2-x86-CSY.exe
WindowsXP-WindowsMedia-KB968816-x86-CSY.exe
WindowsXP-WindowsMedia-KB973540-x86-CSY.exe
wmp11-windowsxp-x86-CS-CZ.exe
OnePiece_Microsoft.NET_Framework_v1.1.4322.2407_True_AddOn_CSY.cab English, Rename in CSY
Can you reupload this link? But server is unavailable... Please reupload it :)
Edited by 15armO88
to all those who downloaded Update Pack CSY, this pack was wincert published only in (so I had not uloadato other server), and so it was only in server wincert, but lately we have had some problems with the server, so some on downloaded this pack, and a good connection, you can upload it to some other server?
@15armO88
Here's hoping that someone who downloaded the pack, and that a good connection can upload it again, or I'll try to do it after me
@George King
eh not even fate still in ita, let you know it always like that, but it is a thing to do, I will find time and also to put in
Hmm, I dont get this.
Explain more.
If I want this to make myself an Dutch IE8 Addon.
What I should do?
I download the executable and selected the folder that contains IE8 installer + needed hotfixes.
Do I need to do more? Or?
Since I am getting an error now. See post here
edit:
I now made an DXUPACFG.ini with:
;OnePiece
[DXUPACFG]
LANGUAGE=Dutch
AddOntype=TRUE
PLATFORM=WinXP
AddOnName=IE
IEAddOnVer=8
Will give it a try.
Edited by Raoul
Hi Raoul, the file in question and KB916157-v4
if you tried to create ie8 addon seems not well configured .ini file (I guess without too much confusion between the first post and second post, first post and only general, and the second post there specific detail the steps to follow,
so when the addon ie8 created, the creator aio maybe you copied to the entries.ini the update pack and not that of ie8addon, aio maker, and designed to create for the first update pack, if you need only create addon is set by well .ini file as described in the second post of the topic.
this should be OK?
;OnePiece
[DXUPACFG]
LANGUAGE=Dutch
AddOntype=TRUE
PLATFORM=WinXP
AddOnName=IE
IEAddOnVer=8
in case you tried to create update, you need to put all the hotfixes in diretory (see for example the list of update pack csy a post above), here be sure to put even the hotfix KB916157-v4
PS: you have a complete list of all hotfixes NLD?, where you can upload it somewhere and send me with PM,
Without these files, these files will or already
IE8-WindowsXP-KB972260-x86-NLD.exe
IE8-WindowsXP-x86-NLD.exe
Windows-KB890830-v2.14.exe
WindowsXP-WindowsMedia-KB952069-v2-x86-NLD.exe
WindowsMedia-KB973540-WindowsXP-x86-NLD.exe
wmp11-windowsxp-x86-nl-nl.exe
I'd like to try to create a pack v2.8.1 NLD
Ciao.
Edited by OnePiece
Hi OnePiece,
Im not creating updatepack, im creating IE8 TrueAddon Only.
I got a different error now, I dont know why, I will re-slipstream everything on clean source and test again.
Edited by Raoul
Tested without the IE8 addon, no errors at all, tehre is something wrong somewhere somehow
Thats how my IE8-make folder looks like. Two folders are emtpy.
DXUPACFG.INI contains:
;OnePiece
[DXUPACFG]
LANGUAGE=Dutch
AddOntype=TRUE
PLATFORM=WinXP
AddOnName=IE
IEAddOnVer=8
Edited by Raoul
@Raoul
you were right, it was a variable that IE8_AddOn not set correctly, so the creator is believed that he was creating update pack, and so did not create an entries_ie8.ini has put in place
and a lot of confusion for myself because they keep changing the variables in order to worship the creator aio (if that could make them a GUI and so set them all, and not have after all this confusion)
@ALL
Check OPMWXPUP.inf OPW2K3UP.inf well, see if the locations are ok ????
Instead all language unicode, you need to put the lines pertaining to the timezone (WindowsXP-KB974176-x86-XXX) ect ect, and after if you also send me in PM
Ciao.
Hi i create CSY localized updatepack with these files:
EUupdate.EXE
KB961184-CS-CZ.exe
msxml.msi
mucltui.cab
mucltui_cs.cab
muweb.cab
rootsupd.exe
Silverlight.exe
WindowsXP-KB926139-v2-x86-CSY.exe English, Rename in CSY
WindowsXP-KB971276-v3-x86-CSY.exe English, Rename in CSY
and when is windows copying files, give me error of one missing file xpsp4Tmp.dll:
How can i fix this error?
Edited by 15armO88
I do not know why the line has not been renamed, because the file xpsp4tmp.dll, will be renamed sprv0405.dll (sprv%MuiCultureLangIdHex%.dll)
if you change it from you entries.ini
Ciao.
Hey OnePiece, can you repair this in OPMWXPUP.inf (0405)?
FROM
ACCESSDIR = "Príslušenství"
WSearch_InfoTip = "Search your desktop"
WSearch_DESCRIPTION = "Provides content indexing and property caching for file, email and other content (via extensibility APIs). The service responds to file and email notifications to index modified content. If the service is stopped or disabled, the Explorer will not be able to display virtual folder views of items, and search in the Explorer will fall back to item-by-item slow search."
TO
ACCESSDIR = "Příslušenství"
WSearch_InfoTip = "Hledat na ploše"
WSearch_DESCRIPTION = "Poskytuje indexování obsahu složek, emailů a dalšího obsahu. Pokud je služba zastavena nebo vypnuta, prohlížeč nebude schopen zobrazit všechny položky a vyhledávání v prohlížeči se přepne na pomalé vyhledávání položka po položce."
And here is "SMALL" bug:
I think under Internet Explorer icons isn´t description :crying_anim02: Can you add it?
HERE is CZECH description
Vyhledává a zobrazuje informace a webové servery v internetu.
EDIT1: And i tried made Update Pack with new Windows Update Agent and your tool won´t work with new file... Maybe i doing some wrong...
EDIT2: New translated STRINGS to CZECH
English:
LOC_UPDATE="Update"
LOC_CRITICALUPDATE="Critical Update"
LOC_HOTFIX="Hotfix"
LOC_SECURITY_UPDATE="Security Update"
PARENT_DISPLAY_NAME = "Windows XP - Software Updates"
WGATip = "Helps customers all over the world who are victims of software piracy get genuine."
CSP_SP_TITLE = "Microsoft Base Smart Card Cryptographic Service Provider Package"
WRMC_NAME = "Windows Rights Management Client with Service Pack 2"
Desc_IMAPI2 = "Image Mastering API"
IMAPI2_TITLE = "Windows Feature Pack for Storage (32-bit) - IMAPI update for Blu-Ray"
Desc_ICCDSCD = "Smart Card Driver"
ICCDSCD_TITLE = "Windows Feature Pack for Storage (32-bit) - Smart Card driver"
Czech:
LOC_UPDATE="Aktualizace"
LOC_CRITICALUPDATE="Aktualizace systému"
LOC_HOTFIX="Hotfix"
LOC_SECURITY_UPDATE="Aktualizace zabezpečení systému"
PARENT_DISPLAY_NAME = "Softwarové aktualizace systému Windows XP"
WGATip = "Pomáhá zákazníkům po celém světě, kteří se stali obětí softwarového pirátství získat originální software společnosti Microsoft."
CSP_SP_TITLE = "Základní zprostředkovatel kryptografických služeb pro čipové karty"
WRMC_NAME = "Klient pro správu práv Microsoft Windows Rights Management Services s aktualizací Service Pack 2"
Desc_IMAPI2 = "Rozhraní Image Mastering API"
IMAPI2_TITLE = "Sada Windows Feature Pack for Storage (32-bit) - Aktualizace rozhraní Image Mastering API pro média Blu-ray"
Desc_ICCDSCD = "Ovladač čipové karty"
ICCDSCD_TITLE = "Sada Windows Feature Pack for Storage (32-bit) - Ovladač čipové karty"
Edited by George King
Tried this tool with new 11 updates... But got error during copying files... I´m waiting for update...
EDIT: Please update your tool with strings which i posted... Thanks
well i think the tool
only makes the current Update Pack
you can't by pass it
it would be cool if the tool can over pass that
and make for a new files
but that would require a lot of scripting
I know i only tried it... I think he update tool, but now is he too busey.
Does any body know for what are this for INI file?
WLMProductCode=
WLMInstallerCode=
WLMPackageCode=
WLLCProductCode=
WLLCInstallerCode=
WLLCPackageCode=
WLLProductCode=
WLLInstallerCode=
WLLPackageCode=
WLRUPackageCode=
Is it for Windows Live? :blink:
CZECH translate for WMP.inf
	EDITTEXT="&Upravit"
RECORDTEXT="&Nahrát"
TEXT_MRTVS="Nahrané pořady"
@George King & 15armO88
Here's where you have the link of the pack v2.9.0 (attention and was created with the new AIO Maker, that when Nonno Fabio will publish the link)
OnePiece WinXP Post-SP3 UpdatePack v2.9.0 CSY
tabdownload.png Updated (Oct 18-2009)
Hash MD5 874E1CB172593401B3171A974790B31C
Filesize: 110 MB (115854940 byte)
File used to create the pack
directx_aug2009_redist.exe Size-108279664 Hash MD5-3f615f38fdc5ee3a8f142dc6f7594657
EUupdate.exe Size-1675184 Hash MD5-79d4277864cee0269af46c78ac2ce8d2
IE8-WindowsXP-KB971961-x86-CSY.exe Size-809336 Hash MD5-b8e73ee680dc32a9e89bc66b081b9cc0
IE8-WindowsXP-KB973874-x86-CSY.exe Size-520056 Hash MD5-ea2c6a82b14297071f3875c4c80cf389
ie8-windowsxp-kb974455-x86-csy.exe Size-9698168 Hash MD5-2f05a3f77131ab645d63d9f63e3b46a5
IE8-WindowsXP-x86-CSY.exe Size-17013088 Hash MD5-6afa953c7ec7b7417e13e80bdf34376d
IMAPI_XP_SRV2003_x86 CSY.exe Size-1329608 Hash MD5-4e3da24ac91f77160eafd1fab1839588
install_flash_player_ax.exe Size-1962544 Hash MD5-651328afc874d1035d6a1d1151367c7a
KB952011 SmartCard_XP_x86 CSY.exe Size-3281280 Hash MD5-7293fb27d0329631fd46ffa86a155e96
KB961184-CS-CZ.exe Size-1074496 Hash MD5-4245421633ba3a1204c8dcbe180284a1
langpack.exe Size-1167880 Hash MD5-ac9e6d821588c8f69106791e0d2cae9a
LegitCheckControl.cab Size-791516 Hash MD5-e0b4b2118f96a98896ec930dc3120771
msxml.msi Size-2434048 Hash MD5-14e34a6cbd8f060a9c965e39b745657a
msxml2sp6-kb887606-x86-csy.exe Size-978616 Hash MD5-ec71b3df7765a0cf4299e3b4c875e908
MuCatalogWebControl.cab Size-72296 Hash MD5-81d28eea9b6c58ead540426eef9bca6a
mucltui.cab Size-132513 Hash MD5-1ef0b1b27641b1799aa70abb6ce74d3d
mucltui_cs.cab Size-12991 Hash MD5-93a9ce530eb2f659118932bdaa1edc05
muweb.cab Size-99514 Hash MD5-3d1e3ac2ad24ee10975096e63621f71d
(Important, remove the ENU, by the OnePiece_Microsoft.NET_Framework_v1.1.4322.2443_True_AddOn_ENU.cab)
OnePiece_Microsoft.NET_Framework_v1.1.4322.2443_True_AddOn_.cab Size-13352762 Hash MD5-fa68590e2c6ae3a7f95d5cd4b8376838
rootsupd.exe Size-319384 Hash MD5-513252738034cdb7c101a73d92e116a6
Silverlight.exe Size-4938616 Hash MD5-06d0d39d31cc12a641ffc06bd0beed9f
Windows-cs-CZ-KB974266.exe Size-706368 Hash MD5-98e7b2e89642a158b7abb006dd302644
windows-kb890830-v3.0.exe Size-9092032 Hash MD5-b17e5baffed9f1836c862dc240a5a651
Windows-KB909520-v1.000-x86-CSY.exe Size-646944 Hash MD5-d404436567ba0a76758c42e35d12e34b
windowsmedia11-kb928788-x86-intl.exe Size-1184672 Hash MD5-4e16f2e5d4687cd2bb90d5ffcaba7772
windowsmedia11-kb929399-v2-x86-intl.exe Size-641440 Hash MD5-a780de538c0360eabed54ed4dc4d9bdb
windowsmedia11-kb929773-x86-intl.exe Size-958800 Hash MD5-56900e172a6939a8d35d46568b34049e
windowsmedia11-kb932390-x86-intl.exe Size-1066912 Hash MD5-df0906458cc0ae6e89f942e407f00980
windowsmedia11-kb933547-x86-intl.exe Size-555424 Hash MD5-184a598d58402089fb3d7a85349098ee
windowsmedia11-kb935551-x86-intl.exe Size-581536 Hash MD5-97ee0912a6c5606e1ad9aa38c1f74cde
windowsmedia11-kb935552-x86-intl.exe Size-715168 Hash MD5-9524078bdc973eb66fe38dabbd4a063e
windowsmedia11-kb939209-x86-intl.exe Size-574368 Hash MD5-c68633dc5e29101f449a132d54029aee
WindowsMedia11-KB939683-x86-CSY.exe Size-568736 Hash MD5-622679b15a860ffa92e877d1b3dea2c6
windowsmedia11-kb944882-x86-intl.exe Size-559680 Hash MD5-b7a2689b14ff797fd16aaf4c2ab4aa1a
windowsmedia11-kb954069-x86-intl.exe Size-997952 Hash MD5-ed35876dbc7401b12007da59dcc9ab0d
WindowsMedia11-KB954154-x86-CSY.exe Size-622144 Hash MD5-b781169f7847cdd52062037011377a44
windowsmedia11-kb973442-x86-intl.exe Size-980368 Hash MD5-1d463d071923fa33bdb5c87deeac4ba0
WindowsRightsManagementServicesSP2-KB917275-Client-CSY.exe Size-2425640 Hash MD5-9cce4e06e55fc10a969619bc9fba3f8e
WindowsSearch-KB940157-XP-x86-csy.exe Size-5459472 Hash MD5-69f0e48d3ecf977f008cbb57f4fea4b1
WindowsServer2003.WindowsXP-KB963093-x86-CSY.exe Size-979208 Hash MD5-94fcd11d5c472c5b1c76b5aabc43adf7
windowsupdateagent30-x86.exe Size-6776168 Hash MD5-f723820b8656e82958fa7ed854a7eefe
WindowsXP-KB817688-x86-CSY.exe Size-918392 Hash MD5-ab6b104f000ae2b05a9c2faea3c880bd
WindowsXP-KB889320-v2-x86-CSY.exe Size-542248 Hash MD5-1484a39a8dadf35e3230ed69733b30b2
WindowsXP-KB897571-x86-CSY.exe Size-1071984 Hash MD5-d1aa165716aadd35f37ba7a68d121719
WindowsXP-KB898461-x86-CSY.exe Size-494320 Hash MD5-a78c2c5879a031001aa62cd229843d85
windowsxp-kb905474-csy-x86.exe Size-1435008 Hash MD5-fae9e1d52705d85cdee2d33a6a7b9d3d
WindowsXP-KB915800-v4-x86-CSY.exe Size-633384 Hash MD5-8d4e9db730236ea9d360a181bc89a8ed
WindowsXP-KB916157-v6-x86-CSY.exe Size-2373496 Hash MD5-3df957a33f1ee8850e197e8eecfeb65d
WindowsXP-KB922120-v6-x86-CSY.exe Size-547880 Hash MD5-7756faad87bce20dc3d570435fa0f07f
WindowsXP-KB923561-x86-CSY.exe Size-1276816 Hash MD5-adba8fb77aec3db257ada7479ed07191
WindowsXP-KB926139-v2-x86-CSY.exe Size-1693224 Hash MD5-5dec374b7b81234e709a4a6ee4fd573d
WindowsXP-KB927436-v2-x86-CSY.exe Size-508456 Hash MD5-dad0b13b2314f81ffb6b46fa973e112f
WindowsXP-KB932716-v2-x86-CSY.exe Size-782888 Hash MD5-b74a16b032f57a2427b1f9dfd55033cd
WindowsXP-KB934401-x86-CSY.exe Size-523304 Hash MD5-41bcd945aa116cb6e62578a71f263c4b
WindowsXP-KB938759-x86-CSY.exe Size-831856 Hash MD5-424b03f86ccf6c48d69ab6474f0440d6
WindowsXP-KB940159-v2-x86-CSY.exe Size-531320 Hash MD5-2764d0e71d4b88d6a79bdceeb283240b
WindowsXP-KB940648-x86-CSY.exe Size-615464 Hash MD5-876823088c7b2f5ed78a0025ed61fa2b
WindowsXP-KB941569-x86-CSY.exe Size-2173504 Hash MD5-c3c1afb10b2871267d486baaa9448e99
WindowsXP-KB942288-v3-x86.exe Size-3327000 Hash MD5-448447e0ba4560cd558eddb5f5b0809e
WindowsXP-KB943232-v2-x86-CSY.exe Size-749936 Hash MD5-a38cbede0a8d0b3f4c98890f0c8bfdbc
WindowsXP-KB944043-v3-x86-CSY.exe Size-1640488 Hash MD5-dc2600ec7d3c656ed53ba1a984a9f8b4
WindowsXP-KB945060-v3-x86-CSY.exe Size-590888 Hash MD5-1e967006a6c53e4257a8c59312ffa34f
WindowsXP-KB945184-x86-CSY.exe Size-611368 Hash MD5-59e2d8fdbbb94ea733796039da858e62
WindowsXP-KB945436-x86-CSY.exe Size-519720 Hash MD5-45627553db9c548d2302447a1d9b1678
WindowsXP-KB946648-x86-CSY.exe Size-536104 Hash MD5-c7454ea5e7c1e513c432512ab2f8ae18
WindowsXP-KB947460-v3-x86-CSY.exe Size-758128 Hash MD5-eaafcbb1dd93a102a8d47d4708c6169d
WindowsXP-KB948101-v3-x86-CSY.exe Size-601640 Hash MD5-3bedb84825efc5400b3d217ba9055beb
WindowsXP-KB948277-x86-CSY.exe Size-1409064 Hash MD5-85a9498a17241a85920d284ac29e762a
WindowsXP-KB948720-x86-CSY.exe Size-793128 Hash MD5-edd1eb461a463a3a47b444237e6e1911
WindowsXP-KB948877-v2-x86-CSY.exe Size-502824 Hash MD5-5b56e50d5ece421cda0031e08f3a5ba2
WindowsXP-KB949127-v2-x86-CSY.exe Size-1371176 Hash MD5-6c43f867bfd1c0b476ac1959dc9c2987
WindowsXP-KB949900-x86-CSY.exe Size-532520 Hash MD5-273cdb48ecc614aa0c4d424897e06e64
WindowsXP-KB950305-v2-x86-CSY.exe Size-1308712 Hash MD5-c499c2115be8ac0543078f6d941e7a81
WindowsXP-KB950312-x86-CSY.exe Size-644136 Hash MD5-09781629eddffebbc2d8b7577ab4dffb
WindowsXP-KB950616-x86-CSY.exe Size-569384 Hash MD5-97b1e5be3a5c36e0e0b70e865b75c494
WindowsXP-KB950820-x86-CSY.exe Size-583208 Hash MD5-ebaf9802b6a5be9e1591a52ac62ec517
WindowsXP-KB950974-x86-CSY.exe Size-602664 Hash MD5-42f745b2c6b97de674fd6042d3838034
WindowsXP-KB950982-x86-CSY.exe Size-639528 Hash MD5-c1f8bd64ae3e6b319b9b6328aece27a5
WindowsXP-KB951066-x86-CSY.exe Size-825896 Hash MD5-82ff39b6797cadf2f5bc632639a6a61f
WindowsXP-KB951159-x86-CSY.exe Size-5198376 Hash MD5-5c8bb6eadc59ae0cfc7a84b08b4683d3
WindowsXP-KB951163-x86-CSY.exe Size-1092648 Hash MD5-1e18c3ffb9d4a5e40900c1ec78ad3d43
WindowsXP-KB951347-x86-CSY.exe Size-579624 Hash MD5-becb3ca18e1e5fe6c681a73088db39dd
WindowsXP-KB951376-v2-x86-CSY.exe Size-612904 Hash MD5-b5cbd5ada340efbef03bfab16bb26356
WindowsXP-KB951531-v2-x86-CSY.exe Size-572456 Hash MD5-c8c31257c98856f5674aa26aa8306cfc
WindowsXP-KB951618-v2-x86-CSY.exe Size-2032680 Hash MD5-e7876f09b33acd1bf3db81a8d793afe4
WindowsXP-KB951624-x86-CSY.exe Size-733736 Hash MD5-f824041b4316c5e65cc704ed012adc37
WindowsXP-KB951709-x86-CSY.exe Size-524840 Hash MD5-41f00c3292516f5fa5cebf2ee55ad20d
WindowsXP-KB951822-v2-x86-CSY.exe Size-517672 Hash MD5-f121c17036af2475dfd18d07753934ad
WindowsXP-KB951978-x86-CSY.exe Size-1134632 Hash MD5-75cf88bf2c92e6a7344b03716f96a967
WindowsXP-KB952004-x86-CSY.exe Size-1032744 Hash MD5-df883c33a4dd301ccf0284d6ccdd64c2
WindowsXP-KB952117-v2-x86-CSY.exe Size-639016 Hash MD5-30bfcfb9e2a56f13ddb2379ffec447c3
WindowsXP-KB952595-v3-x86-CSY.exe Size-556912 Hash MD5-8f2784278431f2420385719386494f96
WindowsXP-KB952909-v2-x86-CSY.exe Size-650792 Hash MD5-1216751520be2d50a29044201570026c
WindowsXP-KB952954-x86-CSY.exe Size-540200 Hash MD5-b345ffabd78679f6dd4ec71f93277418
WindowsXP-KB953024-x86-CSY.exe Size-904560 Hash MD5-506ddfdd4acac4efe30800e67e8d2b9f
WindowsXP-KB953028-x86-CSY.exe Size-1037352 Hash MD5-aad89b43368b91e945b4292e2e6937ed
WindowsXP-KB953155-x86-CSY.exe Size-585256 Hash MD5-cdca6fb72e1b433981daafffa4ff9d0c
WindowsXP-KB953761-x86-CSY.exe Size-564776 Hash MD5-c03f4e80ee9cf1821cdc7785eaa89ea1
WindowsXP-KB953930-x86-CSY.exe Size-511528 Hash MD5-702dea4c7c5892e709277590bfbff670
WindowsXP-KB954193-x86-CSY.exe Size-1323048 Hash MD5-fb23b966504147f28bfff50bba8c14cd
WindowsXP-KB954232-x86-CSY.exe Size-562728 Hash MD5-4a559b48f537f57633be5c0290d1effd
WindowsXP-KB954434-x86-CSY.exe Size-609320 Hash MD5-6f26e194547128932766fec28d6aacae
WindowsXP-KB954708-x86-CSY.exe Size-1021480 Hash MD5-ef2bc7e485b8b8da8deb24e7379e355d
WindowsXP-KB954920-v2-x86-CSY.exe Size-949288 Hash MD5-c0f0552346776f87481e3c4d68d3bec5
WindowsXP-KB955043-v2-x86-CSY.exe Size-617000 Hash MD5-c3692cdf14f3825fc0d61366addf6869
WindowsXP-KB955109-x86-CSY.exe Size-862760 Hash MD5-b7f1b0aa13519b7cbd22f04e05040482
WindowsXP-KB955356-x86-CSY.exe Size-528424 Hash MD5-6749bb46a0c15a655e7dbb028e2fa36c
WindowsXP-KB955417-x86-CSY.exe Size-541224 Hash MD5-fefc4d07fde86f9b139f32c0dfbf173b
WindowsXP-KB955567-x86-CSY.exe Size-590376 Hash MD5-86b6449f97ae39e1e69ed66483c98aca
WindowsXP-KB955576-x86-CSY.exe Size-609832 Hash MD5-083652cf7a94c6be674649212787bec7
WindowsXP-KB955704-x86-CSY.exe Size-3415592 Hash MD5-185e26f839a626c8b616ce086e76ebc2
WindowsXP-KB955830-v2-x86-CSY.exe Size-514416 Hash MD5-bc39947daa681afa84737e2317b6c48b
WindowsXP-KB955843-v4-x86--x86-CSY.exe Size-808488 Hash MD5-52769fe1745d997fe2baf014cc20db0d
WindowsXP-KB955843-v4-x86-CSY.exe Size-808488 Hash MD5-52769fe1745d997fe2baf014cc20db0d
WindowsXP-KB955988-x86-CSY.exe Size-952360 Hash MD5-a21bf932cbbf84be4223ea47065d8577
WindowsXP-KB956048-x86-CSY.exe Size-569720 Hash MD5-bc26665c2b63fe0e34bdd461f3133366
WindowsXP-KB956072-x86-CSY.exe Size-572968 Hash MD5-8bda4bd0d3064f3527435b3ab50fe951
WindowsXP-KB956572-x86-CSY.exe Size-4660624 Hash MD5-4e1b6a5c6e75ae8727470ff9aadea1ba
WindowsXP-KB956625-x86-CSY.exe Size-641064 Hash MD5-dd2e81353a47b50ce58515ed331e77f9
WindowsXP-KB956844-x86-CSY.exe Size-571768 Hash MD5-6feb551f9bbcbc82a44bc8a4cf284a22
WindowsXP-KB957218-x86-CSY.exe Size-595496 Hash MD5-3c5c6a0801ddba02ba68a7fd726f1175
WindowsXP-KB957495-x86-CSY.exe Size-558120 Hash MD5-41597bf89e091a465fd67c3e58892fb1
WindowsXP-KB957502-x86-CSY.exe Size-1960488 Hash MD5-a3d0212d2c5453581ede4f8c3423b885
WindowsXP-KB957579-x86-CSY.exe Size-1260944 Hash MD5-cf5c50fc1f69aaf694c4293c0ba400de
WindowsXP-KB957931-x86-CSY.exe Size-554864 Hash MD5-96601494b517d5d6f94c3abc8c89ce84
WindowsXP-KB958071-x86-CSY.exe Size-532008 Hash MD5-a688433030b897b92d4952a4d524f115
WindowsXP-KB958149-x86-CSY.exe Size-541040 Hash MD5-0ebb9dacad15621a38c2a8268115cc36
WindowsXP-KB958244-x86-CSY.exe Size-580648 Hash MD5-161f6f1965b4b3b26a9bcd9786a6d6b9
WindowsXP-KB958259-v2-x86-CSY.exe Size-1065840 Hash MD5-606aedfc2da3c6d72f11ce8a674fa402
WindowsXP-KB958644-x86-CSY.exe Size-656240 Hash MD5-421898dc72d7234d28109658f70a1996
WindowsXP-KB958687-x86-CSY.exe Size-665968 Hash MD5-62e790cf79b8fe655f4a3320774fa6d5
WindowsXP-KB958817-x86-CSY.exe Size-690544 Hash MD5-e5880d1a60bffb431df391ba41c49a45
windowsxp-kb958869-x86-csy.exe Size-1313136 Hash MD5-d5e2b6fc0102d01943a0d462f9e8ff65
WindowsXP-KB958910-x86-CSY.exe Size-536432 Hash MD5-c8d1ad463bd6d1a9074bf932f57d4daf
WindowsXP-KB959085-x86-CSY.exe Size-1241464 Hash MD5-121852cbb4cd0fae65e2079d1a271769
WindowsXP-KB959160-x86-CSY.exe Size-894848 Hash MD5-8857ba6f6b670689a7527fde9955e69a
WindowsXP-KB959267-x86-CSY.exe Size-556912 Hash MD5-a41de544d49a369d9cf628acebe40957
WindowsXP-KB959334-x86-CSY.exe Size-569712 Hash MD5-9864aeb8e0f1f1b22a8c5088c811bb47
WindowsXP-KB959426-x86-CSY.exe Size-860544 Hash MD5-d9da003b26c7a185e34ce1e4f19ffce4
WindowsXP-KB959465-x86-CSY.exe Size-555376 Hash MD5-3a27c5eda6dbd3f01544d626f3471737
WindowsXP-KB959540-x86-CSY.exe Size-933232 Hash MD5-1ed6621a2e92f802cfcc94557265c109
WindowsXP-KB959554-x86-CSY.exe Size-643952 Hash MD5-82a710b264129d1fc67c5323c2faead8
WindowsXP-KB959682-x86-CSY.exe Size-1032560 Hash MD5-51fa07cf1fce68253bfa71d07fad5b18
WindowsXP-KB959765-x86-CSY.exe Size-525680 Hash MD5-ebbabf9c058e20892e13a9bc5710c46b
WindowsXP-KB959873-x86-CSY.exe Size-570224 Hash MD5-8fcc2f5c9371b2b5cfb471fe03216a2d
WindowsXP-KB960064-x86-CSY.exe Size-1048432 Hash MD5-6ceaf6088ce7e60a0acab1ad4e76a022
WindowsXP-KB960071-v2-x86-CSY.exe Size-715632 Hash MD5-650e6ac288bd598fc3f93459c24784d3
WindowsXP-KB960519-x86-CSY.exe Size-520048 Hash MD5-e3c26419fdf15b292e10a025df9da42e
WindowsXP-KB960655-x86-CSY.exe Size-524656 Hash MD5-a036e48a6281bcd5b471d59e4d8adca4
WindowsXP-KB960680-v2-x86-CSY.exe Size-547184 Hash MD5-f631df8b6cebaa726f3b0b13a399a988
WindowsXP-KB960803-x86-CSY.exe Size-678768 Hash MD5-d778374075625f174eb5aa8f2d7684d8
WindowsXP-KB960859-x86-CSY.exe Size-567664 Hash MD5-8d3ff4f319ceb963b70671107c75c64b
WindowsXP-KB960921-x86-CSY.exe Size-541040 Hash MD5-37cdaf0cc6f71e6b8c14de8c350ce74c
WindowsXP-KB960970-x86-CSY.exe Size-533376 Hash MD5-fad9444346a449588af1607a79148122
WindowsXP-KB961067-x86-CSY.exe Size-612720 Hash MD5-f50adbc27b3637ce788f98e32e15b65a
WindowsXP-KB961118-x86-CSY.exe Size-699760 Hash MD5-3e14e1dca15d69a3b2b917dc6fb90e39
WindowsXP-KB961187-v2-x86-CSY.exe Size-2385264 Hash MD5-24a7b98ef7e89e5c22a92f3e641f3a1a
WindowsXP-KB961371-v2-x86-CSY.exe Size-576376 Hash MD5-9bbb90e28d44fcb4dc8ec7b49ce93d18
WindowsXP-KB961451-v2-x86-CSY.exe Size-658800 Hash MD5-557bd8dd7cb6ee84710a8d3b0c79c514
WindowsXP-KB961503-x86-CSY.exe Size-582544 Hash MD5-c7a227625e69eec56c2d4e9e243f66b7
WindowsXP-KB961605-x86-CSY.exe Size-562040 Hash MD5-3f64f60b56ed57ebe53d0a875548ade5
WindowsXP-KB961729-x86-CSY.exe Size-919408 Hash MD5-29afc9b4aca93ac5ec76b3066dc370e4
WindowsXP-KB961853-v2-x86-CSY.exe Size-680336 Hash MD5-7a607fab8f29ceb46e4466a7145be71b
WindowsXP-KB963038-x86-CSY.exe Size-548224 Hash MD5-4c4e388b0eb47c054c46fdaad921a34c
WindowsXP-KB965220-x86-CSY.exe Size-610688 Hash MD5-209510e308b35b910b72aa8f207a4d2a
WindowsXP-KB967048-v2-x86-CSY.exe Size-516464 Hash MD5-d281d93d1f997ee8b5ee7fb1b7069b0c
WindowsXP-KB967705-v2-x86-CSY.exe Size-629624 Hash MD5-48de01f7f954e4d9d5f03ad768b73144
WindowsXP-KB967756-x86-CSY.exe Size-1505680 Hash MD5-b6bddbce62e0b5ad4e6a5a3b00600d53
WindowsXP-KB968389-x86-CSY.exe Size-1425776 Hash MD5-b6252f82443c49e84d0a9629d9e7231c
WindowsXP-KB968585-v2-x86-CSY.exe Size-661872 Hash MD5-f91d84454d5be58a36b6b6af42aae3e8
WindowsXP-KB968730-x86-CSY.exe Size-760720 Hash MD5-d9fbbeffbb9524a8fc82d58b06215008
WindowsXP-KB968764-x86-CSY.exe Size-579456 Hash MD5-9fb76aa0ad397277dc789e000924d058
windowsxp-kb969059-x86-csy.exe Size-1070960 Hash MD5-824a8f8de7dd908aecd6d7637da410eb
WindowsXP-KB969111-x86-CSY.exe Size-564112 Hash MD5-bc31e9817b7e17315ed78b1eab304990
WindowsXP-KB969238-x86-CSY.exe Size-598392 Hash MD5-42514e227a91ccf46da34baaee5e7ca0
WindowsXP-KB969262-x86-CSY.exe Size-798096 Hash MD5-919d6fd82b7ad0269aca4df19be5a6cf
windowsxp-kb969395-x86-csy.exe Size-729456 Hash MD5-dcb4859466f8607b5cc0386e324c8930
WindowsXP-KB969557-x86-CSY.exe Size-1137024 Hash MD5-04ff138b61cb8f0d94ce7249c930c5f8
WindowsXP-KB969632-x86-CSY.exe Size-665488 Hash MD5-3ed9f594a53101e939d7ac1d85b60205
WindowsXP-KB970048-x86-CSY.exe Size-522640 Hash MD5-b46c0c9d148b3cb6655d0bd8c040a1e0
WindowsXP-KB970063-x86-CSY.exe Size-773496 Hash MD5-0e6fe36b83d550d0fc88f8cc2dd1aa37
WindowsXP-KB970238-x86-CSY.exe Size-889232 Hash MD5-d6eeb84972005ed07175edd97556a0a3
WindowsXP-KB970254-x86-CSY.exe Size-582000 Hash MD5-c85b358944cd4725fd0420437319c8a7
WindowsXP-KB970326-x86-CSY.exe Size-868728 Hash MD5-c889be24d7d561beadf4cfd09d851475
WindowsXP-KB970413-x86-CSY.exe Size-570768 Hash MD5-9a90820289a36a9266a4cf6eada711b1
WindowsXP-KB970483-x86-CSY.exe Size-612720 Hash MD5-4b1555e2cced60e3bb86b642d3c74aec
WindowsXP-KB970553-x86-CSY.exe Size-577936 Hash MD5-df9a04342f1b0deb925d759b22168f4b
WindowsXP-KB970685-x86-CSY.exe Size-538480 Hash MD5-0cb7d9a350e16f7846a287127130d04a
WindowsXP-KB970922-x86-CSY.exe Size-654712 Hash MD5-bd05b33b2722b430e35bd013e5be5415
WindowsXP-KB971029-x86-CSY.exe Size-3253624 Hash MD5-4b479cc0d66033d4186443b9553eed89
WindowsXP-KB971165-x86-CSY.exe Size-635248 Hash MD5-6c00b49abf7f3eb46754c62c91ef60b9
WindowsXP-KB971234-v2-x86-CSY.exe Size-547192 Hash MD5-ba52615fdc4888a57cbd163881fb9b7c
WindowsXP-KB971250-x86-CSY.exe Size-1433968 Hash MD5-b3f1576fc302cd8b4be5a8136e0d0a3a
WindowsXP-KB971276-v3-x86-CSY.exe Size-3278200 Hash MD5-3b5fc543e3cfe1a7943614ee66daafdc
WindowsXP-KB971314-x86-CSY.exe Size-646000 Hash MD5-4f4191f103188ab6aa7dfa314a161f86
WindowsXP-KB971323-x86-CSY.exe Size-553336 Hash MD5-45d0b45332d392ef2883bcfc9ab8ccba
WindowsXP-KB971345-x86-CSY.exe Size-525680 Hash MD5-4a25106e8c7742e9672e193244f63fac
WindowsXP-KB971421-x86-CSY.exe Size-718704 Hash MD5-22bc622ce6221027188309be54a7872a
WindowsXP-KB971455-x86-CSY.exe Size-634232 Hash MD5-7ba6136fe3bb1d350ea38c30ed4daa90
windowsxp-kb971486-x86-csy.exe Size-2708848 Hash MD5-aa705698d3b38b3dfedd53edc8c83121
WindowsXP-KB971557-x86-CSY.exe Size-543088 Hash MD5-0d885ace24a02b932422662a9cf12265
WindowsXP-KB971633-x86-CSY.exe Size-1054072 Hash MD5-b13320ee8839257553239caffc7cc157
WindowsXP-KB971657-x86-CSY.exe Size-569208 Hash MD5-555856d8b5ff6a5c3d93a8d92ee519a8
WindowsXP-KB972422-x86-CSY.exe Size-592752 Hash MD5-630d8e4a39f367c7936198ee4ac3903b
WindowsXP-KB972435-x86-CSY.exe Size-507256 Hash MD5-f59d8189ec627db9e95a84d1ecbffdbe
WindowsXP-KB972828-x86-CSY.exe Size-1231728 Hash MD5-f0618180836a536c62a22a45f731b050
WindowsXP-KB972878-x86-CSY.exe Size-536440 Hash MD5-e02ca9ccff038851f218f21fc8a0fa0a
WindowsXP-KB973093-x86-CSY.exe Size-790904 Hash MD5-3ee150c236bba63d7c7b8100f85831c9
WindowsXP-KB973296-x86-CSY.exe Size-584560 Hash MD5-b0eabd4c316afabf34ebde90c2e40606
WindowsXP-KB973354-x86-CSY.exe Size-1072496 Hash MD5-8209df0cd1c75ba2097ff4e25d370001
WindowsXP-KB973502-x86-CSY.exe Size-520568 Hash MD5-72e68913390be33bb9341d2b28143de7
WindowsXP-KB973507-x86-CSY.exe Size-531320 Hash MD5-964ec9856775b591a846e03b5ffe2ca2
windowsxp-kb973525-x86-csy.exe Size-507248 Hash MD5-4c1e8199daa8fef4a2c9753408325d6a
WindowsXP-KB973624-x86-CSY.exe Size-533872 Hash MD5-e8fdc305eff19573fd104c70be2cd2f7
WindowsXP-KB973815-x86-CSY.exe Size-577392 Hash MD5-2ff0f76e6acf29f46213a1f86441656a
WindowsXP-KB973869-x86-CSY.exe Size-554352 Hash MD5-85e7eb19fb54930409f53c3aa21ae947
windowsxp-kb974112-x86-csy.exe Size-613240 Hash MD5-623b9f6ab20d6241682ec2c515a80c07
WindowsXP-KB974176-x86-CSY.exe Size-519536 Hash MD5-7f490c991188e4e27a91d2f1fb316920
windowsxp-kb974571-x86-csy.exe Size-529776 Hash MD5-3384d7c7f7fedb7c5ce1fc8540f9c8ac
windowsxp-kb975025-x86-csy.exe Size-664952 Hash MD5-6fd42765240fcf1859067b545937e3d4
WindowsXP-KB975254-x86-CSY.exe Size-551800 Hash MD5-e69b9cb992ba5e2961e42542141e0b97
windowsxp-kb975467-x86-csy.exe Size-758136 Hash MD5-05df027870f14bec94c2aee6a4fc4a9b
WindowsXP-WindowsMedia-KB952069-v2-x86-CSY.exe Size-7719816 Hash MD5-c2f96b545ac2a4ca80d1bbbd3b568382
windowsxp-windowsmedia-kb954155-x86-csy.exe Size-1105800 Hash MD5-13f5f33b4e464c0f32b179598eb2b859
WindowsXP-WindowsMedia-KB968816-x86-CSY.exe Size-4414864 Hash MD5-0d8ba1d120b44341a55070df469c3707
WindowsXP-WindowsMedia-KB973540-x86-CSY.exe Size-10021264 Hash MD5-c49fae9a78e6283381dd3992b8845f1a
wmp11-windowsxp-x86-CS-CZ.exe Size-25787976 Hash MD5-107f6a60811c2511bc5e03b6b3372f07
missing only the KB948698, if you tried to ask http://thehotfixshare.net
Edited by OnePiece
