May 25, 200916 yr Here is my reviews of some of antivirus and which antivirus is good for me.As u know there is lots of virus coming out daily. If ur connected to internet than probability of getting virus is very high. I used some of the antivirus and among those this i liked NOD32. The reason why.Norton AV.This seems to give lots of false alarm and uses lots of memory for operation. Scan is also slow. In some old pc it makes pc so slow that u choose to keep virus than antivirus.Kaspersky It is very naggy and display which app is lauched what it is doing etc.. this is make really angry and makes u turn it off. Similarly it consumes lots of memory while scanning making pc slow and scan is also not so fast. NOD32 This is the best antivirus i think. I have been using this now and using other av instead of this was my mistake.This uses very less memory in comparision of other while scanning as well as while running in backgrounf .it is not naggy like kaspersky and scan is also fast. Time to boot for it is also fast.It doesn't even feel like there is AV running in my pc while using nod32.So i don't need to turn it off while playing games. this is reason why I choose NOD32. And after going to eset's "why eset?" i think i can trust on nod32.here is some of why eset images:www.eset.comu can also go to eset.com to know about more.if u think i should not use nod give me reasons. And say which AV I should use; this are my true reviews of antivirus and i am not promoting any antivirus.
May 25, 200916 yr I am a fan of NOD also. I have done test with NOD, Zone Alarm and AVG. I also thought NOD as more PC friendly.
May 26, 200916 yr I agree that NOD32 is the best after using Kaspersky since version 3.5! Since 3 month Nod32 is on my machine (it was only to test it), have no problem and XP is booting great! 5 STARS in every way! :thumbsup_anim:
May 27, 200916 yr Author Would have been interesting to see avast in there.i was thinking of using avast but after seeing eset's why eset.. i didnot use any other a.v and directly downloaded nod4 .. ( as had also previously used nod )
May 28, 200916 yr Author Love avast antivirus pro with Nod32 4.0if u put 2 antivirus then the result i see i CRASH,,, or very low performance
May 28, 200916 yr Love avast antivirus pro with Nod32 4.0Why do you use 2 antivirus programs? What's the point?
May 29, 200916 yr Author ^^ Maybe he just wants the best protection as much as possible with 2 antivirus i think only thing u get is low perpormance & negative impact in money $$..
May 29, 200916 yr lol at least you know your safer with 2 programs then just the one...but i think they would be fighting over who has more control over the firewall and stuff......lol
May 29, 200916 yr i've been using eset nod since version 2.5 its only gotten better over the years in detection, but also slightly more resource hungry since v2 a counterpoint to all this was a discussion about how antivirus software doesnt really do much of anything http://www.ryanvm.net/forum/viewtopic.php?t=7102
June 2, 200916 yr I have just reformated my PC and i just have outpost free as firewall and no AV, i use scan on demand like virustotal or others.Before, i used Avira Antivir, seems to be the best free AV around.
June 3, 200916 yr Author i won't switch to other AV now.. i will stick with nod32.. i think it is not that much resource hungry..i have also been using this since v2
June 3, 200916 yr i won't switch to other AV now.. i will stick with nod32.. i think it is not that much resource hungry..i have also been using this since v2I have also been using it from v2, and now its at v4 and there have been ALOT of changes. Much better scanning speeds, really good virus definition base, doesn't flash to many false positives (compared to others, almost none). I wont change av until something better comes out.
